AOD with 4.11's ?
Forum Name: Transmissions
Forum Description: For discussion relating to all Ford Transmissions
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=2189
Printed Date: 26-March-2026 at 5:40PM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: AOD with 4.11's ?
Posted By: lynchster
Subject: AOD with 4.11's ?
Date Posted: 04-May-2009 at 4:28PM
I'm trying to decide on a gear ratio for an engine / trans swap in my "other project" a 79 ranchero. I have a 4.11 posi that I once had in the 72 for a short bit. The math works out to a 2.75 final which seems decent to me. Any thoughts?
------------- Chuck 72 Gran Torino Sport 13 Taurus SHO "Mr Pig"
Posted By: PatsPOS
Date Posted: 05-May-2009 at 1:32PM
Sounds like a good plan to me, especially if you're in the hilly half of the state. Even 4.30s would net you a 2.88 final drive ratio with the AOD.
Pat
------------- '75 460 Gran Torino Sport (14.04 @ 97 MPH)
'91 Crown Vic (18.09 @ 75 MPH)
'89 300 F-150 (18.37 @ 73 MPH)
Posted By: starsky76
Date Posted: 05-May-2009 at 2:24PM
DO IT,DO IT!I concur.I did have the 4.30 aod setup in my stang,was a lot of fun and barked the tires on the 1-2 and 2-3 shifts,it was a blast!
Posted By: tod-hog
Date Posted: 05-May-2009 at 2:29PM
Please enlighten the neophyte(s) as to the "math" formula so that we might learn and grow.
Date Posted: 05-May-2009 at 2:33PM
An AOD overdrive ratio is .68,Times that by your gear ratio and that's your final gear ratio in od.You have been enlightened!
Posted By: occupant
Date Posted: 05-May-2009 at 4:46PM
This is my favorite speed/rpm/tire size/axle ratio calculator.
http://www.angelfire.com/fl/procrastination/rear.html
I can figure the speed the car will travel given a set of parameters at whatever engine speed. And I can mess with different ratios and such to find out what would get me the right engine speed on the highways around here.
------------- 15 Cruze LT, 145K, for the wife 08 Uplander LS, 280K, broken again 08 Explorer EB, 248K, backup work car still looking for another something
Posted By: 351BBGTS
Date Posted: 05-May-2009 at 5:26PM
i tried that site and it never works for me. i always get NaN
------------- '73 Gran Torino Sport "H" Code
Out with the Cleveland, In with the Windsor
Cleveland build in the near future
Posted By: Regul8r
Date Posted: 05-May-2009 at 8:13PM
I just did it and YAHOO I like it!
THANKS for the link!
------------- Carl Corey (Moderator/Event Coordinator) Contact ANYTIME! 1976 Ford Elite "Lola Mae" 97 Suzuki Intruder 1400 US Army Retired
Posted By: TomiTomi
Date Posted: 05-May-2009 at 11:55PM
Perhaps http://ultimategto.com/art29.htm?engine=5000&trans=2.54%201.50%201.00%200.00%200.00%200.00%202.63&axle=3.55&tire=215%2070%2014&B1=Load%20Driveline%20Data%20into%20Top%20Speed%20Calculator - this one is a bit easier to use. You don't have to know the diameter of your wheel in inches.
And http://www.allfordmustangs.com/Detailed/608.shtml - here is another, which goes the other way round. It tells you, what RPM you'll have at certain speeds.
------------- Tomi ______________________ http://www.ford-cruising.hu/gallery/thumbnails.php?album=31" rel="nofollow - 1975 Ford Gran Torino S&H 2005 Ford Mustang GT 2011 Ford S-Max
Posted By: 351BBGTS
Date Posted: 06-May-2009 at 4:04PM
Thanks tomi that second one helped alot
Posted By: occupant
Date Posted: 07-May-2009 at 3:47PM
You can't just hit Enter when you're done.
You have to click the CALCULATE button or it just refreshes the screen.
