Print Page | Close Window
'70-'71 429CJ Quadrajet parts needed
Category: Classified Section
Forum Name: Parts Wanted
Forum Description: Looking for parts? Post your want ad here
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=21964
Printed Date: 26-March-2026 at 3:22PM
Topic: '70-'71 429CJ Quadrajet parts needed
Posted By: TV 2M8O
Subject: '70-'71 429CJ Quadrajet parts needed
Date Posted: 23-February-2026 at 8:11AM
Needing the bracket, hardware and solenoid for a '70-'71 429CJ Rochester QuadraJet (see attached).
If anyone has the bits they are willing to let go of or know of a possible source/substitute, PLEASE LET ME KNOW!!
THANKS
Posted By: 72FordGTS
Date Posted: 24-February-2026 at 12:27AM
He is a probationary memeber with no posts and seemingly no interaction with the forum. I'd be cautious.
You can also check with a few q-jet carb specialists for the parts.
https://cliffshighperformance.com/" rel="nofollow - https://cliffshighperformance.com/
https://quadrajetpower.com/" rel="nofollow - https://quadrajetpower.com/
Posted By: TV 2M8O
Date Posted: 24-February-2026 at 4:00AM
Vince,
Have feelers out to Chicago Carbs & QuadraJet Parts.com but I'll shoot a message out to those two places as well...
THANKS Handshake
Posted By: hogfiddles
Date Posted: 06-March-2026 at 7:47AM
member since May '25, but no posts. No other info.......BUYER BEWARE, til better confirmation is received.
Dfox
Posted By: TV 2M8O
Date Posted: 09-March-2026 at 7:03AM
OK, having NO LUCK locating the '70-'71 429CJ QuadraJet solenoid bracket for sale, so I created a drawing of the bracket so if there is someone with the carb and has the bracket and wouldn't mind to pull the brcket and populate the attached drawing with the missing dimensions, I WOULD BE ETERNALLY GRATEFUL!!
Thanks guys!!
uploads/925/RP_38843_BRACKET.pdf" rel="nofollow - uploads/925/RP_38843_BRACKET.pdf
Posted By: TV 2M8O
Date Posted: 23-March-2026 at 11:41PM
I also need the choke stove tube assembly so I've sketched it up in the event someone also has one of these loose they wouldn't mind measuring for me.....
(sorry for the pic being rotated 180 degrees... tried to get it positioned correctly!!Ouch)
THANKS AS ALWAYS!!!!Beer
