Print Page | Close Window
Wheel bearings
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=5343
Printed Date: 26-March-2026 at 2:22PM
Topic: Wheel bearings
Posted By: Turbo301
Subject: Wheel bearings
Date Posted: 12-April-2011 at 5:08AM
While my rear end is up in the air (LOL, but seriously...), I was tempted to look at my wheel bearings. However, the Ford manual makes this look like a scary proposition (pull the axle, support in a special jig, chisel off the retaining ring, press off the bearing, etc.). Is there a way to re-grease the bearings by just partially pulling the axle shaft? I don't have a big press or any fancy tools like the manual calls for to deal with bearings!
1977 Cougar XR7
1980 turbo Trans Am
2009 Pontiac G8 GT
Posted By: Psquare75
Date Posted: 12-April-2011 at 7:20AM
Rear wheel bearings.. Does the rear axle make noise at all, rolling and in turns?
Posted By: Turbo301
Date Posted: 12-April-2011 at 7:22AM
The car's always made a low "chugging" or "woofing" sound as it rolls, and that disappears at speed (more likely it just blurs into road noise). I'm assuming that's the bearings.
When I spin the axle without the wheels on, and unloaded (in the air), it makes some shuddery, clunky noises, but I don't think that's a fair test.
1977 Cougar XR7
1980 turbo Trans Am
2009 Pontiac G8 GT
Posted By: Turbo301
Date Posted: 09-June-2011 at 5:42AM
Now that my daily driver is starting to make the same noises, I'm back to this question: is there a way to re-grease the wheel bearings without a lot of fancy tools/disassembly? If I just pull the wheel stud mounting disc off, will that grant me enough access to the bearings to re-grease them?
1977 Cougar XR7
1980 turbo Trans Am
2009 Pontiac G8 GT
Posted By: orlnslloyd
Date Posted: 09-June-2011 at 6:12AM
Rear bearings are sealed. Gotta change them if they are bad or making noise.
'72, GTSFB, 460, C6, 3.70
Posted By: lynchster
Date Posted: 22-June-2011 at 5:57PM
I had a 75 Nova years ago that made the same noise. I refered to it as the Heartbeat of America. I was my retort to all of my GM oriented cohorts who wouldn't let it go that I was driving a Nova.
13 Taurus SHO "Mr Pig"
