Print Page | Close Window
Strut Rod Bushings - OEM vs Aftermarket
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=7548
Topic: Strut Rod Bushings - OEM vs Aftermarket
Posted By: 72FordGTS
Subject: Strut Rod Bushings - OEM vs Aftermarket
Date Posted: 19-June-2012 at 9:32AM
I am still in the process of rebuilding the front end on my car as time allows. I just got a Moog strut rod bushing kit. They seem to be installed the opposite of the factory bushings. In addition the washer on the strut arm (the one at furtherest from the nut) is reversed so that the cup faces away from the bushing.
I had my strut rod arms and OEM washers poweder coated, so I would like to use them. Further, the washer furtherest from the nut on my factory strut rod is welded in place by the factoy, I cannot remove it.
Do you think running the Moog bushings oriented as Moog instructs with the OEM washers will cause any issues?
Thanks.
Date Posted: 20-June-2012 at 2:06PM
Anyone at all? Someone must have used Moog strut arm bushings here. All I want to do is used them with OEM washers. Is this possible?
Posted By: GranTorinoSport
Date Posted: 24-June-2012 at 7:50PM
I've done it before but I don't think the MOOG set is intented to be installed in the factory orientation. It will fit, it does seem much tighter when you are putting the parts together.
Overall on my 75 it seemed to work fine. But I'm not sure if it is putting stress on other parts, etc. My opinion is that if the assembly is correctly tightented, then you are getting the proper tension and deflection as intended, even if the fit is a little off.
Posted By: Psquare75
Date Posted: 25-June-2012 at 1:40AM
I think the Moog washers need to go backwards.
At least on the Clydesdale Mustangs, they do..
http://forums.vintage-mustang.com/vintage-mustang-forum/620983-real-world-65-strut-rod-bushings-experience-please.html" rel="nofollow - http://forums.vintage-mustang.com/vintage-mustang-forum/620983-real-world-65-strut-rod-bushings-experience-please.html
Date Posted: 28-June-2012 at 5:42AM
I have some photos comparing stock to moog parts.
Here are the Stock vs Moog. Note that Moog has the metal sleeve not included with stock.
Here are the Moog installed with the factory washers oriented the factory way. This is how I want to install them. I don't see a problem with this method.
Here are the factory bushings and washers
Here is how moog wants them installed. Note that the inner washer on my strut arm seems to have been welded so I couldn't remove it.
Date Posted: 28-June-2012 at 2:07PM
That's the problem your inner washer shouldn't be welded. I wonder if that's a 72 thing? I've never seen that before.
Date Posted: 28-June-2012 at 3:29PM
Yeah, I know it shouldn't be, but it looks like it is. I tried to seperate them when I took the car apart and they won't budge. They were pretty mint to, virtually rust free and nothing was seized. It looks like they are welded. They were sand blasted and still rock solid afterwards. My car is an Oakville built car, not sure if that makes any difference.
Do you think there will be any issues running these bushings like I posted?
Posted By: Eliteman76
Date Posted: 28-June-2012 at 6:48PM
Ditch the inner moog washer, and good to go.
Older shot of mine from 3-4 years ago.
Date Posted: 29-June-2012 at 6:05AM
Thanks Andy!
I didn't think it would cause a problem. There seems to be as much or more clearance around the bushing and washer compared to the OEM units, and the Moog bushings are FAR stiffer than the OEM ones (although I am sure age is a factor).
Were the inner washers on your car welded in place too? I wonder if that was a 1972 thing...
Date Posted: 01-July-2012 at 5:35PM
Honestly, I don't know. I think they were loose. I pulled 4 more strut rods out of storage today cleaning up things, and all were tagged 1972, and washers were loose.
Posted By: The Torino Kid
Date Posted: 21-June-2025 at 11:50AM
Do youi still have the part number for these Moog's? ty
1973 Gran Torino Sport CJ 351
'Q' code 63R body
Date Posted: 24-June-2025 at 2:04AM
The part number is K8207.  I am not sure if they are still available as Moog seems to have really reduced their product line since the original post.
We have all the Moog part numbers listed here:
https://forum.grantorinosport.org/suspension-part-numbers-stock-replacement_topic17118.html" rel="nofollow - https://forum.grantorinosport.org/suspension-part-numbers-stock-replacement_topic17118.html
Date Posted: 24-June-2025 at 7:41AM
so since the k8207 is no longer available, i havent seen an alternative discussed yet for these. I have the poly's but now that Ive been reading they have a tendacy to snap the strut rods and Im not interested in buying the high end adjustable ones.
'Q' code 63R body
Posted By: Inkara1
Date Posted: 24-June-2025 at 10:00AM
Rare Parts sells them.
https://www.rareparts.com/MNFA689-16337-STRUT-ROD-BUSHING" rel="nofollow - https://www.rareparts.com/MNFA689-16337-STRUT-ROD-BUSHING
Posted By: Rockatansky
Date Posted: 24-June-2025 at 10:22AM
O'Reilly's shows a complete kit available, competitive with Rare Parts after shipping
https://www.oreillyauto.com/detail/c/precision-chassis/precision-chassis-strut-rod-bushing/opm0/k8207" rel="nofollow - https://www.oreillyauto.com/detail/c/precision-chassis/precision-chassis-strut-rod-bushing/opm0/k8207
Date Posted: 24-June-2025 at 12:47PM
Rockauto shows the precision kit is available but out of stock.
It cross references to HB1064K which is used by Napa and TRW.  Try doing some searches for that part number too.
Date Posted: 25-June-2025 at 7:01AM
thanks for the link. Clap
'Q' code 63R body
Date Posted: 25-June-2025 at 7:02AM
i appreciate the link. thank you.
'Q' code 63R body
Date Posted: 25-June-2025 at 7:08AM
found it on ebay, thank you.
'Q' code 63R body
