Print Page | Close Window
WHATS A 351 4V FOR A 1971 WORTH+SHAKER HOOD SCOOP
Forum Name: 1970-1971 Ford and Mercury
Forum Description: Technical discussion for 1970-1971 Ford and Mercury
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=771
Printed Date: 26-March-2026 at 11:31AM
Topic: WHATS A 351 4V FOR A 1971 WORTH+SHAKER HOOD SCOOP
Posted By: LANCE75801
Subject: WHATS A 351 4V FOR A 1971 WORTH+SHAKER HOOD SCOOP
Date Posted: 18-September-2006 at 5:56PM
I HAVE A COPMLETE 351 4 V OUT OF A 1971 TORINO (MIGHT BE A 70) WITH THE SHAKER HOOD SCOOP  IT HAS BEEN SETTING IN A BARN FOR AT ALMOST 20 YEARS I INHERTED IT A FEW YEARS BACK I I JUST THOUGHT IT MIGHT BE WORTH SOME MONEY TO A COLLECTOR I WAS EVENTULLY PLANNING TO USE THE HEADS ON A 302 W AND PUT A ROLLER CAM IN IT BUT DEPENDS ON HOW MUCH THEY ARE WORTH
Posted By: NW Alex
Date Posted: 28-September-2006 at 6:07PM
 Many peaple will have many different answers to this question !
 I have a project that would truly benefit from what you have  .
 If you could tell me any part numbers off any of the parts ,
 intake manifold , exhoust manifolds , carb , shaker scoop ,
 block ( on the block down in the starter motor area ) ,
 any  numbers would be good . Also if you could tell me
 in what part of the country are you located ? My email
 is mailto:skipjackauto@comcast.net - skipjackauto@comcast.net .
                                          Thank You
Posted By: Guests
Date Posted: 22-December-2006 at 5:45AM
Im interested in the car that the motor came out of. How much for it and where are you located. TIA mailto:userid@cfl.rr.com - userid@cfl.rr.com
Posted By: 57honey
Date Posted: 12-January-2007 at 6:28AM
Check e bay.  Shakers can bring anywhere from 200.00 to 1500.00 depending on condition of course, what parts are there, and whats missing if any.  I do believe you may have a tough time using the 351C heads on a small 302 , 351w though. unless I misunderstood what you're trying to do.  also, shakers are different on different models.  boss 302s, clevelands, and BIG blocks.  good luck.Wink
