Print Page | Close Window
Tilt column rebuild maybe?
Forum Name: General Automotive Technical Discussion
Forum Description: Technical Automotive discussion of anything not specific to mid-size Ford/Merc
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=8950
Printed Date: 26-March-2026 at 6:34PM
Topic: Tilt column rebuild maybe?
Posted By: JoeKarasinski
Subject: Tilt column rebuild maybe?
Date Posted: 02-April-2013 at 4:49PM
I've got two column shift tilt columns. I noticed after installing the 1st one it has a little side to side play in the top of shaft. I hadn't noticed it before installing it but then again I wasn't looking for it. I don't remember how many miles were on the car it came out of. So I'm looking at the other column and it too has a little play but I think less than the 1st one so I tore it down today and repainted it to match and I'm going to use it. I'm wondering if this is normal in tilt column or if I need new bearings. Any one have any experience with this? I wanted to inspect them so I took the snap ring out and expected the bearing would slip out but they don't. I see 2 notches that I could try to pry the race out with but I was a bit worried about damaging them. Back in the 80's and early 90's I rebuilt a lot of columns  for work. Theft recoveries but never did a ford like these. Always GMs and Chryslers and newer fords like escorts and mustangs. I'm betting these were never stolen too much the column is built like a tank.
