Print Page | Close Window
73 351C 4bbl "Q" Camshaft
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=9702
Topic: 73 351C 4bbl "Q" Camshaft
Posted By: vegasmax
Subject: 73 351C 4bbl "Q" Camshaft
Date Posted: 26-August-2013 at 4:49PM
Does anyone have the specifications of the camshaft that was installed in the 73 Torino with "Q" Code 351C 4BBL engine w/4-speed? Also is it 4 degrees retarded that year? And was it done with the cam gear or cam grind settings? Also if you guys know which year cams were better than the others and why? Thanks Geek
Posted By: 72FordGTS
Date Posted: 27-August-2013 at 2:39PM
According to the info I have the 1973 351CJ is basically identical to the 1972 351 CJ other than the larger combustion chamber in 1973 which lowered the compression ratio.
The cam for the 1972 engine has the following specs:
270° Intake / 290° Exhaust, 46° overlap
.480" Lift Intake/ .488 Lift Exhaust
The cam timing events were 4° retarded for 1972 (and 1973). I believe this was through the cam, but I am not 100% sure on that one.
Posted By: sabatona
Date Posted: 27-August-2013 at 2:45PM
Retarding of the cam was done by the sprockets only. If you replace the sprockets and chain you will remove the retarding of the cam.
73 GTS 351 4V Q Code
Blue Glow/Blue Int
1 of 1
Date Posted: 27-August-2013 at 3:12PM
That's what I thought, but the info I have shows that the 1972 Cam was 4 degrees retarded, but as far as I can tell it used the same sprocket on the crank as a 1970-71 engine. From Bubba's site it shows that only in 1973 it started to use a retarded crank sprocket.
%20" rel="nofollow - http://grantorinosport.org/BubbaF250/parts/parts03.html
Also, the 1971 vs 1972 camshafts have different part numbers, so that's why I figured the retard was ground in the cam. But again, I could be wrong.
Posted By: Rockatansky
Date Posted: 29-August-2013 at 2:08PM
here's some info,
http://home.comcast.net/~jelerath/mustang/Specs/cams-fr.html" rel="nofollow - http://home.comcast.net/~jelerath/mustang/Specs/cams-fr.html
Posted By: ThunderOnTheRoad429
Date Posted: 04-September-2013 at 2:15AM
Ford didn't measure the cams @ .050" back then like they do today.  If you put the best of everything, the cam before they retarded it, closed chamber heads, 4V intake and exhaust, Duel point distributor, you would end up with 365 HP.  I did this years ago.  I ordered the stock cam from a local Ford dealer.  It wasn't anything to brag about.  I can recommend a cam to you if I new a little more about what you expect for performance. I will tell you that unless your cam has at least 220 degrees of duration on the intake side,  you're not really taking advantage of the Clevelands potential.
Waylon & Buddy
Posted By: vegasmax
Date Posted: 04-September-2013 at 2:45PM
here is what speed pro said it was and their replacement for it:
Ron the CS-650 camshaft is the part number for your application and when installed with the timing marks lined up is 5 degrees retarded, attached is the camshaft specification sheet.
Part Number:CS 650
                                Cam Lift / Intake:        .278"                                           Cam Lift / Exhaust:       .283"
                                Valve Lift / Intake:      .481"                                           Valve Lift / Exhaust:     .490"
       Valve Lash Int.:HYD                        Valve Lash Exhaust: HYD             Cam Type:            FH
Lobe Intake Centerline:   120        Lobe Exhaust Centerline   :110             Separation Angle:  115
LOBE CENTERS
R.R =
1.73
I.O (BTC)
I.C. (ABC)
E.O. (BBC)
E.C. (ATC)
DURATION
 INT      EXH
OVER LAP
INT. (deg)
120
SAE J604D
16
91'
80'
47'
287'
307'
000
EXH. (deg)
110
.050 CAM LIFT
17'
43'
44'
-3'
206'
221'
000
Notes: Firing order 1-3-7-2-6-5-4-
Date Posted: 04-September-2013 at 3:32PM
The 206' 221' is what I would pay attention to.  It would make sence if they where @ .050"  206' will give you a super smooth idle. good fuel mileage & excellent torque.  Thats what the stock cam was designed to do AND keep the vehicle under warentee.  Now, in a 351C let's say a cam w/ 206' is stock.  a cam w/ 212' is an RV cam. Still has good torque and fuel mileage but has a noticable increase in HP. 218' would be a street performance cam.  Fuel mileage would suffer, but now you have a cam that would bennifit from a lager than stock carb. headers, intake & ignition and still have excellent vacuum to opperate power brakes.  224' is the largest cam you could use w/ your stock convertor in an automatic.  A rear end gear change at this point from the stock 2.75:1 to 3.00:1  to a performance gear set.  Let's say 3.25:1 to a 3.70:1  but there goes your fuel mileage.  A 230'cam.  @ this point your idle is rough, you may need a seperate vacuum pump to opperate power accessories.  Headers, gears, and convertor  are a must.   What I did was go 6' changes on the cam's intake and show you what you could expect.   When in dought, go with a smaller cam, like the 218' and you'll be much happier than if you went one step to large.  Hope this helps.
Waylon & Buddy
Date Posted: 04-September-2013 at 3:35PM
That stock Cleveland cam was GROUND 4' retard.  NOT THE CAM SPROCKET...
Waylon & Buddy
Date Posted: 04-September-2013 at 4:12PM
here's some Cleveland cam info I've been saving, some good 'updated' recipes by George Pence
http://www.network54.com/Forum/136503/thread/1234512198/Elgin+Pro+Stock" rel="nofollow - http://www.network54.com/Forum/136503/thread/1234512198/Elgin+Pro+Stock
Date Posted: 04-September-2013 at 5:07PM
E-1225-P  would be my choise.
Waylon & Buddy
Date Posted: 04-September-2013 at 10:08PM
i'd order a custom ground 'improved' cam from Bullet
if there was any change in the timing set, depending upon model year & application, it was the crank sprocket that changed. if you have the 2 in hand and line up the key slots you can see the difference at the tooth
Posted By: iangj
Date Posted: 05-September-2013 at 11:27AM
It IS the sprocket that has the retard in it. Always been a quick fix for better performance to put in a quality aftermarket timing chain & gear set to zero the cam.
Ian Glyn-Jones
Fonthill, Ontario, Canada
Wish I had My Baby Back
Montego GT Registry
Posted By: vegasmax
Date Posted: 05-September-2013 at 4:02PM
Looks like a 268H cam with no retard timing gear will work ok for street and not kill mileage? Anyone agree? Or suggestions. 73 351 Q code cj lower compression 4bbl heads and intake all stock w/4 speed 325 gear.
Date Posted: 05-September-2013 at 5:07PM
Absolutely! 268H would be / is my 'off the shelf' pick for a mild combo with a stock torque converter and rear gear all the way down to 2.75. obviously with the steep highway gear it won't be a bullet off the line but it doesn't suffer either, my 73 made 20 mpg
with the manual trans and 3.25's you can get away with a little cam though, the Elgin E-1225-P may shine there if you like dual pattern, or E-907-P for a single... maybe even a little more cam?
268H very good cam  or the extream energy which would give you a little more duration and lift on the exhaust side, which the Cleveland could use.
Waylon & Buddy
