Oil pan woes
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=9772
Printed Date: 26-March-2026 at 5:41PM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Oil pan woes
Posted By: torkair
Subject: Oil pan woes
Date Posted: 08-September-2013 at 1:42PM
The past couple days I have been trying to
get this 460 into my Ranchero and I keep running into the same god
forsaken problem of THE OIL PAN IS HITTING THE ENGINE CROSS MEMBER!!!
The first pan has a huge front sump on it and was clearly a front sump
truck pan, the second one has a smaller sump and managed to get the
engine just a hair away from seating on the cross member, but again, we
are sitting on the pan. So is there any sort of help out there for me?
Do I need a different pan? A big hammer? Or a burning rag hanging out
of the gas tank as I push it out into the street? I am seriously at my
wits end here!!!
------------- 72 Gran Torino "sport"- in progress
Posted By: madmaxtorino
Date Posted: 08-September-2013 at 1:57PM
Do you have the correct motor mounts?
------------- Allan Revelation 6:8 When there is no more room in Hell, the dead will walk the Earth.
Posted By: torkair
Date Posted: 08-September-2013 at 4:06PM
I am using the Anchor motor mounts that I bought a while ago. The pan I am most recently having a problem with has an approximately 8" deep sump that is approximately 12" from front to back. I just recently picked up another pan that is also 8" deep but is approximately 10" from front to back. As it is the motor is just a hair away from dropping right into place but instead it is sitting right on the cross member with the oil pan. Such a pain...
Date Posted: 08-September-2013 at 4:10PM
anchor doesnt make the correct mounts that is probably your problem.
Date Posted: 08-September-2013 at 4:16PM
http://forum.grantorinosport.org/429-motor-mounts-for-72-torino_topic5217.html" rel="nofollow - http://forum.grantorinosport.org/429-motor-mounts-for-72-torino_topic5217.html
Date Posted: 08-September-2013 at 4:27PM
Not trying to take advantage of your bad luck, but I have a couple sets of these I would sell. Anchors catalog is wrong, the do not have the correct ones.
Date Posted: 08-September-2013 at 4:38PM
http://www.ebay.com/itm/1973-1974-1975-1976-FORD-TORINO-THUNDERBIRD-429-460-ENGINE-MOTOR-MOUNTS-/161055084827?pt=Motors_Car_Truck_Parts_Accessories&hash=item257fa1911b&vxp=mtr" rel="nofollow - http://www.ebay.com/itm/1973-1974-1975-1976-FORD-TORINO-THUNDERBIRD-429-460-ENGINE-MOTOR-MOUNTS-/161055084827?pt=Motors_Car_Truck_Parts_Accessories&hash=item257fa1911b&vxp=mtr
Heres a correct set on ebay, not mine! Mine would be way cheaper.
Posted By: torkair
Date Posted: 08-September-2013 at 5:26PM
If this other pan doesn't work then I may have to get the ones you have. Please PM me with details.
Posted By: GranTorinoSport
Date Posted: 08-September-2013 at 6:21PM
I have what was the Ford MotorSport pan which I believe was built by Canton.
It fits with factory motor mounts, but I do have but 1/4" clearance or so on the passenger side. I will endeavor to get some photos this week.
Just put the motor in, did notice it was close but fit, but compared to the headers, the oil pan is the least of my worries...
What I have is essentially this:
https://www.cantonracingproducts.com/product/15-764/15-764----BBF-FRONT-SUMP-RR-T-PAN/
Of course I will need to measure mine and compare to the one on the webpage, but it is very similar just from a casual look.
------------- Scott Eklund
Posted By: torkair
Date Posted: 08-September-2013 at 7:34PM
After looking at the schematics for that canton pan I feel that that extra bit of clearance on the back side of the sump is just what I need. Here's hoping tomorrow goes off without a hitch after I pull everything out again.
Posted By: aquartlow
Date Posted: 08-September-2013 at 11:47PM
Scott, Could you post pics of the installed oil pan, looking to go with the Canton 15-764 as well. Thank you, Todd
Date Posted: 09-September-2013 at 12:01AM
Torkair, Not sure if you are running headers or not, but without the correct mounts your headaches may not be over  when trying to fit them. IMO, If you can get the correct factory mounts, DO IT. They are getting harder to find in good shape and they will certainly make the 460's installation easier with adequate clearances. Good luck. Hope you get it figured out. Todd
Posted By: Billy C
Date Posted: 09-September-2013 at 8:49AM
Why doesn't someone start making mounts that puts the motor in stock location? I feel like there would be a nice demand for them. If I had a set I would measure them up and make some drawings for folks to to just make there own how ever they wanted. I used a bunch of tire rubber and washers. It's all sorts of sketchy. I wish I could get an OEM set.
------------- -Billy Conturo
Date Posted: 09-September-2013 at 6:10PM
Here are some pictures of the oil pan:
Driver Side: Lots of clearance:
Passenger Side: less clearance
Overall not a problem unless the motor moves quite a bit. For my situation, as I have explained in the rear transmission mount thread, this car was 4x4'd a little by my brother, and as such the crossmember front lip was bent up. I bent it down with a bigger BFH, but maybe not enough, so that may be some of the clearance problem on the passenger side.
Overall, great pan, it does fit, and I believe it is a re-branded Canton as described previously. Strongly recommended.
Date Posted: 09-September-2013 at 11:25PM
Overall, great pan, it does fit, and I believe it is a re-branded Canton as described previously. Strongly recommended. |
Scott, Thank you for the pics. That pan does fit pretty good, maybe a little work with angle grinder/cut-off wheel on the passenger side for more clearance if needed.
Date Posted: 10-September-2013 at 8:31AM
So I guess this makes it a +1qt system (7 quarts total with filter).
Posted By: mcford
Date Posted: 10-September-2013 at 2:04PM
madmaxtorino wrote:
anchor doesnt make the correct mounts that is probably your problem. |
^^THIS^^
When I worked at the zone i ordered in every 460 passenger car mount anchor made. NONE of the m are correct for a mid-sized (Torino)
------------- Mike
