  New Posts New Posts RSS Feed - pulley alignment
pulley alignment
mkshelton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mkshelton Quote  Post ReplyReply Direct Link To This Post Topic: pulley alignment
    Posted: 14-August-2014 at 8:12AM
So I'm putting my rebuilt 351w back together and I can't get the water pump pulley to line up. It's actually so tight to the crank pulley that it can't turn. I'm wondering if the engine guy forgot the crankshaft spacer or something else. Any ideas or experiences?
SininenIII View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SininenIII Quote  Post ReplyReply Direct Link To This Post Posted: 15-August-2014 at 3:48AM
Are the pulleys the same that were there before engine rebuild? Same water pump and damper?
Any pics of the issue?
Edited by SininenIII - 15-August-2014 at 3:49AM
Aatu
73 Gran Torino Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote mkshelton Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 6:19PM
The pulleys are the same but the damper and water pump are both new aftermarket. I just fabbed up a spacer to fit behind the crank pulley and it's lining up pretty good now. :) I'll post up pics once the wife uploads from her camera.
This page was generated in 0.083 seconds.
