  New Posts New Posts RSS Feed - Quarter window trim removal help needed
Wgosser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wgosser Quote  Post ReplyReply Direct Link To This Post Topic: Quarter window trim removal help needed
    Posted: 22-February-2021 at 8:37AM
I am getting ready to install a new vinyl top on my 74 Gran Torino Elite and the only thing holding me up at this point is the removal of the curved quarter window trim. Can’t find any reference anywhere as to how it comes off. Any tips or tricks from anyone would be of great help. I have already removed the drip rail over the window just the curved piece remains so I can install the vinyl top properly. See picture for piece in question. Thanks in advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 22-February-2021 at 5:03PM
wayne, if you removed the driprail, you can remove thoseWink you need to remove the interior panel, remove the quarter window...2 bolts in the metal panel  lower it down into the body to access the screws in the fuzzy seal theres about 4 or 5 of them may be hidden in the fuzzy, they are phillips head screws, remove the interior plastic sail panel piece around the opera windows too, be careful those type have a clip in the center of it that pops out from a 1/4" hole ....
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 22-February-2021 at 5:06PM
you may need to also loosen the 2 bolts on the sides of the window bracket to get it to come out of the metal body panel, if so 1 can be accessed from inside and the other is accessed by removing the vent or big round plug in the door jambWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wgosser Quote  Post ReplyReply Direct Link To This Post Posted: 23-February-2021 at 12:52PM
John, thanks for all the info. Got the stationary windows out, opera windows out and top is on, now for trimming around all the windows .
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-February-2021 at 8:36PM
Thumbs Up
