  New Posts New Posts RSS Feed - question on a 91 capri
inenidok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote inenidok Quote  Post ReplyReply Direct Link To This Post Topic: question on a 91 capri
    Posted: 24-August-2011 at 3:38PM
well i am hoping some one might know the answer one of my bosses is redoing a 91 mercury capri first off i dont know why? but he likes it. anyways he repalced the fuel filter and the fuel pump, and the car would not start it will try to on starting spray. he checked and was getting gas, then he checked again no gas then replaced the fuel pump again got gas now no gas so he replaced the relay no gas still. so what is up with that i have never heard of anything like this as far as i know he has replace the fuel lines as well.
thanks for any help
75GranMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 24-August-2011 at 3:53PM
find the inertia switch and check for power when key is cycled to the on position.should have power on pink/black wire.i think thats the correct color.power times out after afew seconds.at this point you can work forward or back if its a fuel supple problem.does he have a fuel pressure gauge?
Post Options Post Options   Thanks (0) Thanks(0)   Quote inenidok Quote  Post ReplyReply Direct Link To This Post Posted: 24-August-2011 at 4:10PM
i dont know i will have to check i am going over there this weekend if possible to check. but i will get one to see. i will check that wire and the switch i wonder if that car has a ignition box on the column like the older cars?
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 25-August-2011 at 2:19AM
I had one of those. Loved the way it ran and handled, but finally sold it after much ribbing from friends. I would say it is probably the inertia switch as well. That car contains mostly Mazda parts, so replacements are easy to find.
