  New Posts New Posts RSS Feed - Radiator fit issues
Radiator fit issues
npsdemon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote npsdemon Quote  Post ReplyReply Direct Link To This Post Topic: Radiator fit issues
    Posted: 05-January-2014 at 3:54PM
Hi Everyone!!
I am new here and have forgotten most of what I knew about Torinos.  I owned a 72 about 25 years ago.  I have recently purchased a 71 GT, 351C 4v.
My issue is I bought a "direct fit" fan shroud.  The one on the car is shot, broken beyond repair.  Also a new aluminum Rad that is a "Fits Torino"  Rad fits pretty well, new fan shroud does not fit the new or old rad.
Something is a little strange here.
The rad I got was 21.75 core length, same length as the one that was in the car.
Is this the right Rad for the car?
If not what is the proper core length.
I am not against putting electric fans on the car but I want it to remain mostly stock or stock appearing.
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-January-2014 at 5:41PM
it sounds like it may be the shroud, since it don't fit the new or old rad. what exactly doesn't fit (too tall, short ,too wide, too narrow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote npsdemon Quote  Post ReplyReply Direct Link To This Post Posted: 06-January-2014 at 4:10PM
The shroud is too wide.  The old one is "modified" to fit around the  top rad hose.  that is why I am thinking the Rad is wrong.
The new shroud goes to the tanks of both the new and old Rad.  The new rad is also the same as the old one if it was not cut to allow the upper hose to pass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-January-2014 at 4:43PM
i'm not sure, hopefully someone else may be able to answer this for you, post a couple of pics if you can. i'm just not that familiar with the 70/71
Post Options Post Options   Thanks (0) Thanks(0)   Quote npsdemon Quote  Post ReplyReply Direct Link To This Post Posted: 06-January-2014 at 4:57PM
Ok I will get those tomorrow.  Maybe someone will be able to help out....
71 Torino GT 351C 4v
71 Nostalgia Pro-Stock Demon 358cid
Nostalgia Whelen Series Asphalt Modified
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-January-2014 at 6:10PM
i did some checking for radiators the diamentions i found were 26"x17 7/8" for core, i found one used orig 71 torino rad from a cleveland car they claimed the core size is 21 3/4" x 17 3/4" ???? thats smaller for a cleveland ???? don't make sense to me. but looking at shrouds there seemed to be different part #'s and shapes, all claiming to fit 71 torinos???. i'm thinking your shroud may be the problem ??? hope this helps.
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 07-January-2014 at 7:44AM
THERE ARE 2 DIFFERENT WIDTH FAN SHROUDS OR 70/71 TORINO'S.
This page was generated in 0.111 seconds.
