Radiator Support Bushings and Body Mounts |
Post Reply
| Author | |
mlachance112785
Joined: 31-May-2012 Location: Dighton, MA Status: Offline Points: 343 |
Quote Reply
Topic: Radiator Support Bushings and Body MountsPosted: 23-September-2015 at 9:34AM |
Looking for something verified. I've read about using Chevelle mounts, Crown Vic mounts, Misc. part numbers from Energy. What have YOU used with no issue?
The bigger issue is the radiator support bushings. I'll have to cut mine out. But what have you used for bushings? Thanks in advance.
77 Cougar XR7 460/C6
legend onirot
METAL GOD Joined: 18-January-2009 Location: hattiesburg ms Status: Offline Points: 3038 |
Quote Reply
Posted: 23-September-2015 at 10:22AM |
I used the crown vic body bushings... and i also used them for the radiator support bushings. i had to shim them a little, but no issues.
Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14723 |
Quote Reply
Posted: 23-September-2015 at 1:32PM |
these are what i used:
http://www.ebay.com/itm/310245534809?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2648 9.4102r (softer compound) from energy suspension, and i added a 1/8" thick 1 1/4" flat washer (welded to the top of the frame for support)
Edited by californiajohnny - 23-September-2015 at 1:33PM |
Thanks(1)
Quote Reply
Posted: 23-September-2015 at 1:39PM |
here's the dimensions and how they assemble, for those bushings ^^^
mlachance112785
Quote Reply
Posted: 23-September-2015 at 9:47PM |
Thanks. That's what I figured I'd try. I think Andy used those as well? They're cheap enough too.
For the body mounts, I think I will use the Chevelle ones. Seeing as I'm this far, ![]() I think I should do the body mounts as well. Looking for opinions too: I'm not building a show car, but am I crazy for just recoating the frame from firewall forward? As it is, I'm doing more than I originally wanted. But also don't want to regret not doing it later on down the road.
stanman
Joined: 23-March-2007 Location: Nova Scotia, Ca Status: Offline Points: 1434 |
Quote Reply
Posted: 23-September-2015 at 11:08PM |
I'd lift the body off and change the mounts. You might be surprised how much rust is under them. You're in the salt belt right?
mlachance112785
Quote Reply
Posted: 23-September-2015 at 11:47PM |
I'm changing the mounts regardless.
Yes, I'm in the salt belt. But the car is from Virginia. And never driven in the snow. Hopefully I won't find any surprises.
Post Reply
| Tweet |
