Rear brake drum size - 72 GTS |
Post Reply
| Author | |
zippy289
Joined: 01-June-2023 Location: Los Angeles CA Status: Offline Points: 19 |
Quote Reply
Topic: Rear brake drum size - 72 GTSPosted: 09-August-2024 at 6:38PM |
Hi folks, I've been reading about different drum brake sizes on our cars and noticed some members say to check the size listed on the drum face. Unfortunately my car came with no drums. I did measure the backing plate and it measures to a hair over 11", logic would follow that I need the 11" shoes and drums to fit over the backing plate correct?
Thanks!
Quote Reply
Posted: 10-August-2024 at 1:51AM |
Unless you have a wagon or a police car, they came with 10" drums. The drums flare out so I am not sure the backing plate size, but they are probably larger than 11". It is possible you no longer have original parts on your car.
Inkara1
Joined: 17-November-2021 Location: Ridgecrest, CA Status: Offline Points: 515 |
Quote Reply
Posted: 10-August-2024 at 5:58AM |
Wagons are also 10 inches. The shoes are 2.5 inches wide instead of 2 inches.
Quote Reply
Posted: 10-August-2024 at 6:41AM |
Right, my error. It was the later wagons that had 11" brakes.
Quote Reply
Posted: 10-August-2024 at 9:59AM |
IIRC the lip / edge of the backing plates fit into a groove in the back side of the drums, the backing plates will measure larger than the braking surface of the drums
Post Reply
| Tweet |
