  New Posts New Posts RSS Feed - Rear Control Arm Bushing Replacement
Markb73gtorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Markb73gtorino Quote  Post ReplyReply Direct Link To This Post Topic: Rear Control Arm Bushing Replacement
    Posted: 19-January-2019 at 1:22PM
Hello all, I am about to install new bushings in the rear control arms on my 73 Torino. Looks straight forward but I am not sure what thrust washers are and where to put them in. Any advice would be great. Thanks
Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-January-2019 at 5:09PM
what bushings are you using?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Markb73gtorino Quote  Post ReplyReply Direct Link To This Post Posted: 19-January-2019 at 5:15PM
I am using poly urethane
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-January-2019 at 9:08PM
ok, are you referring to the ring looking things? IIRC they go on the upper arms??? i can look at my car tomorrow...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Markb73gtorino Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2019 at 2:15PM
Hello all, I am replacing the bushings on my rear end of the 73 Torino, all is good except I am having a hard time finding a diagram of the rear end parts so I can make sure I put everything back together correctly. Does anyone have a diagram or can point me to where I can find one. Thanks
Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2019 at 7:09PM
mark, take a look through my thread... there should be a couple pics that may be helpful... i'll dig around through my stuff see f i can find a diagram? i thought the energysuspension bushing came with a diagram??? the lower arms are pretty straight forward the uppers and the thrust washer thing you mentioned was a strange concept, it threw me for a loop at first! basically it goes against the arm outside the small end of the installed bushing to keep the arm from walking over and rubbing against the bracket.
  http://forum.grantorinosport.org/johns-74-sh-clone-build-thread_topic10024.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote Markb73gtorino Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2019 at 9:46PM
Johnny,
Thanks for the reply. The thrust washer I figured out with a video. Looking at the bracket though, there does not appear to be room for a thrust washer. It all fits pretty tight. The diagram that comes with the bushings is general and not specific to the Torino. I am having a hard time finding shop manuals for my car without spending a small fortune. Thanks for the help. When I get better at this I will be able to contribute more to this web site. I am a mechanic that is still in elementary school so to speak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2019 at 11:30AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2019 at 1:10PM
that's ok i've worked on lots of different cars over the years and had to learn particulars about these cars as i went Wink
 i had to trim some of the edge off on the thrust bushing for them to fit too
Edited by californiajohnny - 23-January-2019 at 3:37PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2019 at 1:14PM
the brown or maroon ford manuals are the best i got 2 of the set were in my car when i got it Wink
the haynes and chiltons don't really tell you sh*t IMO!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2019 at 2:55PM
Mark, I am with the others, invest in the shop manuals.  They are invaluable, I use mine all the time.  They make reprints now too and digital versions as well.
I have this pic of the rear suspension that may help:
Edited by 72FordGTS - 23-January-2019 at 2:56PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Markb73gtorino Quote  Post ReplyReply Direct Link To This Post Posted: 24-January-2019 at 1:23AM
That photo worked!! I have started buying the shop manuals. Thanks for all of the links. As I get better at this I will be able to help others too. This web site has really saved my tail. I will post photos when I get the bushings in.
Zeker62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zeker62 Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2025 at 10:07AM
Anyone know if the dimple on the lower rear control arm goes toward front or rear? 1973 torino
