  New Posts New Posts RSS Feed - Rear differential upgrades?
mrbpatsfan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrbpatsfan Quote  Post ReplyReply Direct Link To This Post Topic: Rear differential upgrades?
    Posted: 01-August-2025 at 2:36PM
Hello fellow enthusiasts. My 68 Torino GT came with a FE 390, C6 transmission, and an open differential with a 2:73 GR. The GR is way too conservative. I’m thinking limited slip with 3:25 through 3:73 for around town with 15” tires. Any why nots based on performance? Thanks in advance.
X
Jaybee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybee Quote  Post ReplyReply Direct Link To This Post Posted: 08-August-2025 at 2:00PM
A 3.55 is usually a pretty good compromise between RPM on the highway and good getaway torque on 15" car tires, as opposed to tall sidewall truck tires. With those, sometimes you need to go steeper.
Cars are meant for driving
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 08-August-2025 at 2:50PM
The 390 has plenty of torque to work with taller gearing than a smaller engine. I had 3.25 gears in my first car with a C4 and 351C-4V. That was not too much gear for me at all, I think I'd try the 3.50 gear unless you need lots of highway driving time.
I have 373's in my 1998 Explorer, and in 3rd gear(1:1) it runs 3000rpm at around 60mph. Your car will take shorter tires such as 26-27" I'd guess, so the same gearing should push yours over 3000rpm @60mph.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 08-August-2025 at 6:40PM
I agree with the others.  The 3.25 is a nice all around gear, 3.50 better for someone who doesn't do a lot of highway driving but wants lots of acceleration.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 09-August-2025 at 3:59AM
what performance level are you feeling? you don't mention highway at all but comments all reflect the inevitability of at least some highway time happening. your 390 should not be a slouch in the TQ dept with a 3.78" stroke, that attribute can be used to run a slightly lower numerical gear than say a 289 with a (can't get off it's ass) 2.87" stroke. have you had a play with a gear ratio calculator? or run the car up to speed in D2 and see if 60 mph at that engine rpm is a no-go. do you have a tach? if no maybe get a cheap POS and wire it in temporary just for finding your rpm tolerance threshold?
How Fast Do You Want To Go?
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 23-August-2025 at 2:29PM
I went from 2.73 open to 3.50 traction lok, and it immediately put a grin on my face, but then I hit some highway that rev'd it a bit more than I liked, so, I ended up swapping in a 4R70W to get OD which gave me the best of both worlds.
MARTY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MARTY Quote  Post ReplyReply Direct Link To This Post Posted: 17-October-2025 at 6:07AM
Good afternoon. Just got a 68 gt with the 428 but need to change the rears to something usable.350 or 325  How do I determine whether the axle is 28 or 31 spline. Everything on my build sheet leads me to 31 but I would like to make sure. Thank you
M FLEMMING
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-October-2025 at 9:12AM
4 bolts... pull an axle out and count the spines ....
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 20-October-2025 at 10:58AM
Totally agree with CJ, the most accurate way for a person to know the "actual" axle spline count....unless of course you can't count and/or remember LOL.
This page was generated in 0.120 seconds.
