  New Posts New Posts RSS Feed - Rear Lowering 75 Ranchero
papadeath View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote papadeath Quote  Post ReplyReply Direct Link To This Post Topic: Rear Lowering 75 Ranchero
    Posted: 27-August-2013 at 9:14AM
Anyone have any idea how to lower the rear of a 75 Ranch? Looked for springs but no one seems to have them. Outside of bagging it... Too much money, where can I get lowered springs with out having to cut some?
75 Ranchero in progress
04 Harley Deuce stage one kit
89 Toyota pickup modded
skateboard
4 bicycles
1 scooter
2 dogs
2 stupid cats
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2013 at 9:22AM
I believe you might be able to use a weaker passenger car spring that is not load rated. However, cutting a coil off is not that bad.
...or some bags of cement in the bed with a false floor, LOL.
Edited by unlovedford - 27-August-2013 at 9:22AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote papadeath Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2013 at 9:32AM
I've heard of using a weaker spring, but won't that make my ride slushy? I wanted it to be tighter. And where would I cut my spring? They both curl into pig tails and if I cut it it wouldn't fit into the holder...
skateboard
4 bicycles
1 scooter
2 dogs
2 stupid cats
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2013 at 9:46AM
Weaker spring will not stiffen the ride or aid in handling, that is for sure. I would look for a higher rate spring made for handling - might even cross-check other makes of vehicles and models for an application that could be utilized.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2013 at 10:32AM
Using a cut-off wheel I cut between a coil and 1.5 coils out of my rear springs, I also used a torch to heat the spring to reform the pig tails. I know using a heat source on a coil spring is a bad idea but the pigtails just locate the springs in the upper or lower pockets, I only heated about 3/4 of a coil to reform one end. Doing this really increase the spring rate, firming up the ride and lowered the rear between 4 to 5 inches.
Edited by aquartlow - 27-August-2013 at 10:34AM
OleDutchD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OleDutchD Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2013 at 10:35AM
Coil Spring Specialties
Custom stuff is their bread and butter. You tell them how far you wish to drop it, how firm you need it, and they'll fabricate a set to your specs.
madmaxtorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2013 at 12:56PM
x2 they did the drop springs for my first torino told them 2" drop 20% stiffer
Allan
Revelation 6:8
robot9000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robot9000 Quote  Post ReplyReply Direct Link To This Post Posted: 28-August-2013 at 3:11AM
Check out Eaton Spring.  Send them an email or post in their forum and they will hook you up.
2010 Mazda 6
2007 Jeep Wrangler
2011 Damon Daybreak 35BD
Post Options Post Options   Thanks (0) Thanks(0)   Quote papadeath Quote  Post ReplyReply Direct Link To This Post Posted: 29-August-2013 at 1:41PM
I have Eaton's on the front, they didn't have what I wanted for the rear. I will check out that link. That you very much.
skateboard
4 bicycles
1 scooter
2 dogs
2 stupid cats
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 29-August-2013 at 2:13PM
When I checked into Eaton's for my LTD II wagon, they told me the biggest drop they could do in the rear was 1".  I ended up leaving the rear alone, and cutting 3/4" coil from my front OEM springs.
This page was generated in 0.101 seconds.
