  New Posts New Posts RSS Feed - Rear sway bar link 72/GTS.
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Topic: Rear sway bar link 72/GTS.
    Posted: 03-October-2022 at 1:15AM
Hello forum. Are rear sway bar link kits available for 72/GTS competition suspension? The stud/bolt snapped off on one side…rusty!
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2022 at 12:29PM
They are not available new. You will either have to repair the existing, fabricate a new one or source a decent used one.  Or alternatively, you can order a new Addco rear sway bar which comes with it's own hardware (not interchangeable with stock Ford parts).  This is your most expensive option, but you will also get a larger rear sway bar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2022 at 12:59PM
How big is their rear bar Vince? I have a front one that they made for me one size larger than OEM, they might still do that, custom make one a larger size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2022 at 4:07PM
Give me sec I have one somewhere. I broke one of mine but I'm going to go with a thicker Addco bar.
13 Taurus SHO "Mr Pig"
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2022 at 4:28PM
This what you're looking for?
rebornfastback72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rebornfastback72 Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2022 at 6:41PM
I’ve been looking for the exact same link, After Anderslober of anyone else has one it would be appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2022 at 7:38PM
Yes…that is exactly what I am looking for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2022 at 7:44PM
just out of interest…What is the part number of the Addco rear sway bar for our cars?
Compton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2022 at 8:15PM
938
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2022 at 8:25PM
Ok…938 kit. Thanks. I will tak a look at it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2022 at 7:01AM
There is a thread on fabbing that link. I went with the Adco on mine but the link looks better than the Adco hardware.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2022 at 7:06AM
Where is the thread?…..cant find it…..no sticky…
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2022 at 1:30PM
It's in the how-to section:
If you decide to go with the Addco bar, reuse the axle brackets if they are salvageable.  They bar is good but there hardware could be better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2022 at 2:27PM
Ok….great thread on the rebuild of the links. I was thinkin’…ouch…
Slightly blasphemous idea…..possibly could fit…not OE though.
How about this?👇
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2022 at 3:44PM
I would try to make them before buying those and doing mods.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2022 at 4:59PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 08-October-2022 at 5:23AM
Almost…👇🍻
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2022 at 3:19AM
The above Lexus links are slightly longer than the originals. How much, if any, of a problem would this be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2022 at 7:30AM
For the price of a solid part which is close to what you need, and OEM are obsolete, I might get them and have them shortened by a local shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2022 at 8:43AM
 i'd be more concerned if the bottom part is the same width to fit yours!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2022 at 9:35AM
Better yet, is it more feasible and possible to replace the stock bushings, and repair any damage of the end link itself? I haven't looked at mine, I only know what they look like from pictures on the forum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2022 at 10:41PM
I bought the above Lexus set to test.
What are the measurements of the originals? Length, width..etc?
I have compared pictures of the original and this Lexus link..they look very, very similar in size…..
Bushing-wise…..I will look around….or improvise👍😂
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 14-October-2022 at 12:30PM
Energy Suspension is the standard for urethane bushings, check with them if you don't want to use rubber.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 21-October-2022 at 1:07AM
What bushings did you fellas use for the sway bar eye?
Energy Suspension 9-8141? How do you mount it? Do you cut the bushing in half?
My car is in the shop…..what does the sway bar eye look like? Please post a picture…thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 16-November-2022 at 1:01AM
I decided to buy the Addco 938 kit. Seems like a good upgrade.
Not OE setup….but eminently acceptable I think.
The original links were in poor condition. One broken. I will keep them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-November-2022 at 1:42PM
 i have the addco on mine, i'd recommend using you oem axle brackets and bolt the addco to themWink  as they won't twist on the axle! the addco stuff is just a big "U" bolt or once its mounted where you want it tack weld the clamp ends to the axel tube so they cant rotate on youWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 16-November-2022 at 8:45PM
Great info. The original sway bar axle mounts will come off today. They are a bit crusty. I will clean them up and see if they are reusable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 17-November-2022 at 2:51AM
I couldnt save them…shucks…..anyway…..no worries….will mount the new 938 kit.
