  New Posts New Posts RSS Feed - remave gage cluster
remave gage cluster
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: remave gage cluster
    Posted: 16-June-2022 at 7:28AM
do I have to remove the whole dash. Seems the steering wheel is in the way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2022 at 10:59AM
No, but you will need to put the shifter into "Low" and do a bit of fidgety moving to get it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2022 at 1:43PM
Be careful removing the harness connections and speedo fitting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2022 at 12:31AM
well next time I had it half out and it started to crack. Had more trouble trying to get it back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2022 at 4:03AM
the white plastic deteriorates and crumbles after all these years, the cluster barely comes out far enough to almost get a hand behind it to disconnect the speedo squeeze clip and the harness plug. then there may be a couple wired indicator lamps that need to be disconnected as well. clock disconnect? and maybe another plug IIRC? then the cluster almost has enough room to come out from behind the steering wheel. removing the steering wheel would certainly make things a little easier
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2022 at 7:28AM
Strange speedo came loose without a squeeze clip. Well now I have no speedometer.
