retrofit hybrid kit |
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 5798 |
![]() ![]() ![]() ![]() ![]() Posted: 03-June-2017 at 5:18PM |
anybody caught this one yet?
it's a bolt on electric motor to convert your fossil fueler into a hybrid search Performance TV on Velocity and you might find the latest episode where it was featured
lynchster ![]() Senior Member ![]() ![]() Joined: 07-January-2006 Location: Pennsylvania Status: Offline Points: 2126 |
I just read up on it. Interesting concept.
I noticed at least by this example it may only be a set up for injected engines. Maybe the amount is inconsequential but is it acceptable to hit the nose of the crank with 150 ft lbs of torque it was never designed to accept in that area? |
good point, Ford cranks are pretty tough but some others ... ?
like a blower being driven off the snout, the belt can't be too tight or it can & will break just about any crank. a bud had a private owned military Humvee with the correct diesel power plant, he had the accessory drive belts too tight & broke the crank
