  New Posts New Posts RSS Feed - Running too cool?
Running too cool?
Turbo301 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo301 Quote  Post ReplyReply Direct Link To This Post Topic: Running too cool?
    Posted: 07-May-2010 at 5:45AM
I've noticed that, since installing my new rad, no matter what the temperature is outside or how long I've been driving, my temperature gauge never reads more than the bare minimum of the "normal" range. Normally I'd consider that a good thing - the new rad and coolant are obviously working well - but now I'm wondering if it's running too cool?
I didn't touch the thermostat when I changed the rad and fluid, and before I did it read into the low to mid "normal" on a hot day.
The gauge seems to be working because it rises from the bottom stop to "normal' as the car warms up, and after running, turning it off to hot-soak and then restarting, it peaks a bit and then drops back down.
Is this okay, or should I get a new thermostat to turn the heat up a bit?
Edited by Turbo301 - 07-May-2010 at 5:46AM
1977 Cougar XR7
1980 turbo Trans Am
2009 Pontiac G8 GT
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2010 at 6:27AM
did you purge correctly, maybe you have some air in your circuit Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo301 Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2010 at 6:33AM
Which circuit? I've never heard of purging a coolant circuit (so obviously the answer is "no", I didn't :) ).
1977 Cougar XR7
1980 turbo Trans Am
2009 Pontiac G8 GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2010 at 7:46AM
Is the new radiator aluminum?
