  New Posts New Posts RSS Feed - Sand blast cabinet question
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Topic: Sand blast cabinet question
    Posted: 05-June-2014 at 1:37PM
OK gents, I have a nutty question for all those with a sand blasting cabinet...
The cabinet we got from Jeg's (which is a POS I might add!) has two ports that I'm assuming is an Intake and Exhaust/Vacuum port. The larger of the two is on the back right end of the cabinet and has a chimney on the inside. The smaller port is on the left end of the cabinet and opens directly into the cabinet. Both have a pop off covers to open and close them to the outside.
First, is my assumption correct and second, which is intake and which is exhaust? Confused
THANKS!!
wideone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wideone Quote  Post ReplyReply Direct Link To This Post Posted: 05-June-2014 at 3:21PM
I have a cheap ass one from HF.  The exhaust has a filter to keep the vac from sucking the media out.  I don't see the purpose of an intake since you are feed compressed air in to begin with.  I say use either one for your exhaust and leave the other closed.
BLAST OFF!
