  New Posts New Posts RSS Feed - Sand Blaster
Sand Blaster
swampbug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swampbug Quote  Post ReplyReply Direct Link To This Post Topic: Sand Blaster
    Posted: 31-August-2015 at 2:56PM
I've been looking at buying for my project. Ive seen stand alones, cabinet models, etc. It seems to me the best use for these is small stuff, since if I do body parts, Ill just be wasting the media. Any thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2015 at 3:13PM
I bought a cheap 40 pounder and have used it to do the frame and entire underside of the car. I still have and use the hell out of it. First thing to do is ditch any brass fittings for steel.
More important is your air compressor. I used an old Emglo (1977) 80 gallon tank with a 5 hp 220V compressor.
08 Taurus (Maytag)
03 Dakota (Rusty)
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2015 at 4:41PM
i too have a small 40#? craftsman from sears works great! but is a little slow for big jobs like the entire frame, it will blast it fine , just takes longer.
cabinets are great but unless they are large, you can only fit smaller parts in them (brackets and maybe a wheel) they do make bigger cabinets=bigger priceConfused
then you have the pressure pot type they are good for frames, but can be a little harsh and powerful for sheetmetal like fenders (can warp the thin metal!!!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote swampbug Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2015 at 4:55PM
http://www.eastwood.com/eastwood-50lb-pressure-abrasive-blaster.html
so these are the types to choose from? pressure or syphon?
Edit: Also looks like a gravity feed blaster as well. So which is best for stripping paint?
Edited by swampbug - 01-September-2015 at 5:01PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2015 at 6:13PM
here's the one i have: (think i paid $39 or $49 for it about 20 years ago)
 http://www.sears.com/craftsman-50-lb-sandblaster-kit-with-1-4-in/p-00916706000P
Post Options Post Options   Thanks (0) Thanks(0)   Quote swampbug Quote  Post ReplyReply Direct Link To This Post Posted: 02-September-2015 at 12:44AM
How is maintenance on this? Hose get abraded quickly? Replacement nozzles?
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 02-September-2015 at 1:28AM
i bought a 100 pound sandblaster similar to the eastwood one.
chuck is right, the air compressor is important.  i used a 40 gallon married up to a 5 gallon air compressor.  still was slow, just have to take your time.
the hose on mine eventually wore through.  i had oreillys cut me a power steering hose about 6 foot.  works great.  the ceramic nozzles are replaceable and cheap.  the valves are easily replaceable, you can buy them at lowes or home depot.
i did all my sandblasting on stacy lynn with this sandblaster.  the frame, suspension parts, under the body, etc.  (dont sandblast body parts with sand) i think i paid around $100-120 but that was 5 or 6 years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote swampbug Quote  Post ReplyReply Direct Link To This Post Posted: 02-September-2015 at 1:40AM
what do you use for body parts? glass/soda?
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 05-September-2015 at 3:56AM
I've used iron oxide but that's dangerous especially if you've never done it. The most important thing is distance and movement because warping sheet metal is easy.
08 Taurus (Maytag)
03 Dakota (Rusty)
Post Options Post Options   Thanks (0) Thanks(0)   Quote swampbug Quote  Post ReplyReply Direct Link To This Post Posted: 05-September-2015 at 4:07AM
ive been reading on it. Just enough air pressure to do the job, different media have different % of inbed.  Don't stay on one spot too long, friction will raise temp, warp metal
NorthElite View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthElite Quote  Post ReplyReply Direct Link To This Post Posted: 21-September-2015 at 11:56PM
With larger parts local metal shop help me with professional sand blasting tools. With smaller parts I have sand blast cabinet. This came with vacuum cleaner, so it keeps dust inside in it. I run it with 8hp compressor. Sand blast cabinet works well, but It does not make any miracles. With heavy rusted parts I use acid dipping to help getting rust out.
I have one of these dual blasters too. It works with soda and sand, but my compressor is too small with it. I can only sprayed lots of sand or soda, but nothing is happens with it LOL
