Sand Blaster |
swampbug ![]() Member ![]() ![]() Joined: 19-August-2015 Location: South Carolina Status: Offline Points: 130 |
![]() ![]() ![]() ![]() ![]() Posted: 31-August-2015 at 2:56PM |
I've been looking at buying for my project. Ive seen stand alones, cabinet models, etc. It seems to me the best use for these is small stuff, since if I do body parts, Ill just be wasting the media. Any thoughts?
lynchster ![]() Senior Member ![]() ![]() Joined: 07-January-2006 Location: Pennsylvania Status: Offline Points: 2127 |
I bought a cheap 40 pounder and have used it to do the frame and entire underside of the car. I still have and use the hell out of it. First thing to do is ditch any brass fittings for steel. More important is your air compressor. I used an old Emglo (1977) 80 gallon tank with a 5 hp 220V compressor.
i too have a small 40#? craftsman from sears works great! but is a little slow for big jobs like the entire frame, it will blast it fine , just takes longer.
cabinets are great but unless they are large, you can only fit smaller parts in them (brackets and maybe a wheel) they do make bigger cabinets=bigger price ![]() then you have the pressure pot type they are good for frames, but can be a little harsh and powerful for sheetmetal like fenders (can warp the thin metal!!!) |
http://www.eastwood.com/eastwood-50lb-pressure-abrasive-blaster.html
so these are the types to choose from? pressure or syphon? Edit: Also looks like a gravity feed blaster as well. So which is best for stripping paint?
Edited by swampbug - 01-September-2015 at 5:01PM |
here's the one i have: (think i paid $39 or $49 for it about 20 years ago)
http://www.sears.com/craftsman-50-lb-sandblaster-kit-with-1-4-in/p-00916706000P |
How is maintenance on this? Hose get abraded quickly? Replacement nozzles?
legend onirot ![]() Senior Member ![]() METAL GOD Joined: 18-January-2009 Location: hattiesburg ms Status: Offline Points: 3036 |
i bought a 100 pound sandblaster similar to the eastwood one.
chuck is right, the air compressor is important. i used a 40 gallon married up to a 5 gallon air compressor. still was slow, just have to take your time. the hose on mine eventually wore through. i had oreillys cut me a power steering hose about 6 foot. works great. the ceramic nozzles are replaceable and cheap. the valves are easily replaceable, you can buy them at lowes or home depot. i did all my sandblasting on stacy lynn with this sandblaster. the frame, suspension parts, under the body, etc. (dont sandblast body parts with sand) i think i paid around $100-120 but that was 5 or 6 years ago.
what do you use for body parts? glass/soda?
I've used iron oxide but that's dangerous especially if you've never done it. The most important thing is distance and movement because warping sheet metal is easy. |
ive been reading on it. Just enough air pressure to do the job, different media have different % of inbed. Don't stay on one spot too long, friction will raise temp, warp metal
NorthElite ![]() Member ![]() Joined: 22-February-2015 Location: Finland Status: Offline Points: 195 |
With larger parts local metal shop help me with professional sand blasting tools. With smaller parts I have sand blast cabinet. This came with vacuum cleaner, so it keeps dust inside in it. I run it with 8hp compressor. Sand blast cabinet works well, but It does not make any miracles. With heavy rusted parts I use acid dipping to help getting rust out.
![]() ![]() I have one of these dual blasters too. It works with soda and sand, but my compressor is too small with it. I can only sprayed lots of sand or soda, but nothing is happens with it ![]() |
