Seat belts from Seatbelt Planet |
Page <12 |
Eliteman76 ![]() Admin Group ![]() Joined: 20-March-2006 Location: Nebraska, USA Status: Offline Points: 4870 |
Can you send over his contact info?
I have questions for him
1973gts ![]() Senior Member ![]() ![]() Joined: 05-March-2018 Location: Grand Rapids Mi Status: Offline Points: 557 |
The phone number is 405-283-2851 and they are located in Oklahoma. Just call that number and ask for Steve, he's the one that sets up the systems and does the special order set ups. Also, I didn't ask him but the female end I measured had a sleeve on it, be nice if Steve could set up a sleeve end for our purposes.
Dave - 1973 GTS N code
Just ordered a set of these, talked to Steve and he is putting a sleeve on a 12 inch female end, he also said the kit comes with 4 90 degree brackets which can be bent to 130 degrees for the female end attachment which should make the angle correct to sit alongside the seat right. Also the cost he gave me was $302.59 for this set up with a 4 week delivery date. Also for r9b2 Steve said you can order the female end separately with or without the sleeve if you want the shorter length.
Edited by 1973gts - 20-May-2022 at 2:29PM |
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5442 |
Keep us posted Dave. If you take lots of detailed install pics, we could to a "How-to" post. I can help you put the post together as long as you take lots of pics.
handsofstone ![]() Senior Member ![]() Joined: 13-April-2018 Location: Northeast Status: Offline Points: 3827 |
I have two sets of cc 4v heads and one set of oc. I assume your heads are cc but if you need a set let me know.
lynchster ![]() Senior Member ![]() ![]() Joined: 07-January-2006 Location: Pennsylvania Status: Offline Points: 2127 |
Is yours a 72? This configuration looks entirely different than the one on my fastback.
I talked to Steve today and learned a few things.
Nice guy. If going with his set up and installing a new carpet don't bother cutting holes in the carpet for the seatbelt buzzer and warning light. They won't work with the new set up. If you want the rear to match the new front belt set he can re-web the rear retractors and install the newer ends to them so that you can replace the receiver ends for the back seat as well.
Page <12 |
