  New Posts New Posts RSS Feed - Seat Belts
Seat Belts
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Topic: Seat Belts
    Posted: 15-October-2017 at 6:17AM
Has anyone on here upgraded their seat belts on there 72-73 Torino?  I would like to add in rear three point belts for my kids and I figured I could upgrade my front belts too.
For the rear belts I'd kind of like to have the retractors mounted in the trunk somewhere.  I figure that the trunk floor or wheelhouse is more solid than the package tray.  Plus, it'd look much cleaner.  Here is a pic I found on a Chevelle.
My concerns would be where to mount the actual retractor.  I am also not sure how to fee the belt through the package tray.  The picture about has some sort of belt sleeve, but not sure where to find that.
If I was doing the rear belts, I'd also like to do the fronts.  There are a lot of universal setups out there, but I am not sure how well they will work with our Torinos.  I'd like to use the stock mounting points for the front belts.  I figure modern three points would probably be more comfortable, while also probably safer overall (due to the better retractors).
I have seen some setups too with these drop mounts on the ceiling. I was thinking they might work well since the shoulder belt mount points are pretty far back on the '72-73 cars.
Any advice is appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 15-October-2017 at 6:35AM
vince, does your car have the roof mounting point like in the pic ^^^above? if so it would be easy to convert the front belts!
 74+ have a lower double mounting bracket i have some brackets you would just need to get 74 -79 2 dr belt retractors
the rear IDK can be done but not sure what to use?
Edited by californiajohnny - 15-October-2017 at 6:52AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 15-October-2017 at 6:42AM
If you come thru the package tray, you need a way to ensure that the belt will not fray or shear against the edge of the metal in an accident.
havanariviera View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote havanariviera Quote  Post ReplyReply Direct Link To This Post Posted: 16-October-2017 at 2:10AM
http://www.seatbeltsplus.com/product/MS6473CPB-Rear.html
I've been doing some very preliminary research as I have the same questions/concerns for the rear seat of my 72. I can post a few websites I came across offering conversion kits.
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 16-October-2017 at 2:50AM
I have the passenger side front seat belt harness set-up from a '79 Cougar (2 door), if you're interested.  Pay the shipping, and it's yours, if you want to play around with it.  It's blue.  I've also got the shorter buckles too.  Just don't have the driver's side harness.
Jeff
72 base Torino (modified)
72 Gran Torino Squire
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 16-October-2017 at 12:56PM
The stock 1972-73 seat belts mounts are like in the picture I posted above (which is a Chevelle).  They are further back than the 1974-76 Torino shoulder belt mounts.  This is discussed in this thread here:
It doesn't seem to me that there is any definitive conclusion on if the later belts will work or not in the older cars.  I am also not sure if they floor mounts for the retractors are the same for the 72-73's and the newer cars.
The fraying of the belt is a big concern if I mount them below the package tray.  From a quick look at the tray on my car, I'd probably have to cut slots in the tray for this to work, then figure out how to prevent the belts from rubbing on the sharp metal.  I do like the clean look, but it's a lot of work.  The photos that I posted from that Chevelle, the guy used parts for a 2009 Camry to may it work (the belts are aftermarket though).
I also was doing some more searching through the archives and I found that member Sininenlll did do this conversion.  He did it a little differently than most of the other conversions I have seen.  Typically the retractor is mounted up high like on modern cars, with the two factory belt mounts being just solid belt mounts.  He mounted the retractor down low, mount a seatbelt loop up high on the package tray area.  It works, but it's just not as clean as other installs.  I means that you have two belts running up the seats instead up one (because it's looped over).
Edit:  after looking at his pictures more closely, I think he actually used 3-point non retractable belts.
Here is his install:
 These are custom reinforcement "L" brackets he fabbed:
Here is that thread:
It seems most of the aftermarket kits have the belt retractors mounted on the package tray. Of course there are no kits for Torinos.  I did see one company called Morris offers reinforcement prackets for the package tray mounts.  This might be a viable option, but I have to fab up my own package tray reinforcement.  Below is pics of a Morris kit installed in a Chevelle.
Here is the Morris reinforcement bracket.  I think something like this would work for a Torino.
Another concern for the front belts is the unique style floor mounts that the Torino uses for the front belts.  I am not sure any of the aftermarket retractors could mount to it correctly.
Jeff, I might take you up on your offer.  I am not as concerned about the front belts at this point but it would be nice to have something less restrictive and safer than the original belts.
Edited by 72FordGTS - 18-October-2017 at 8:27AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-October-2017 at 3:09PM
there is a difference in the buckle / latch in some of the seatbelts 72,73,74 are the same connection but some 74's are like the newer style buckle...
 the 74-79 front belt retractor mounts are different if you need the 74+ front mounts let me know i have several that can be removed Wink
Don V. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 16-October-2017 at 4:45PM
Have you considered a 4 point harness? I see them more and more and I've wondered if it isn't an extension of the awareness brought about by the car seat laws. Good harness's are available now in the same price range as shoulder belts and should require a lot less thought to the geometry when compared to a locking shoulder belt. Of course I'm assuming their use for children is legal everywhere. The harness is more restrictive but it would also be a rare circumstance where it wouldn't be safer should something happen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 17-October-2017 at 1:54AM
Sounds good Vince.  Let me know.  They are kinda heavy, so shipping to Canada may get a little expensive.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 18-October-2017 at 8:25AM
Jeff,
do you have a picture of the seatbelt mount on the '74+ Torinos?  Just wondering how different it is from the '72-73 cars.
Don,
4-points are too restrictive for my needs.  The main reason I'd upgrade the front belts is for comfort, instead of the solid mount shoulder straps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 18-October-2017 at 12:08PM
Vince,
I can't argue with that. My thoughts for the 4 point were for the kids in the rear. The shoulder straps on a 4 point can often be done without permanent alterations to the car and won't have the geometry issues that come with some impact locking belts. For the kids, they are safer plus some insurance companies offer discounts for 4 and 5 point harnesses for kids. They do here anyways.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 20-October-2017 at 4:40AM
So I had a little time to do some searching and it looks like the 1972-73 front seatbelt mounts are quite a bit different than the 1974 and newer mounts.  Here are some pictures I found for comparison:
Here is the 1972-73 style floor mounts:
Here are the 1974 and newer style:
So I think retrofitting the newer style retractors to the 1972-73 cars would be difficult without changing the mounting tabs.  I also found a couple of good pictures to show the difference in the shoulder strap locations.  The 1972-73 cars were much further back compared to the 1974 and newer cars.
Here is a 1972-73, note how far back the shoulder belt is mounted to the roof:
Here is a 1974 and newer style:
Since the 1972-73 style tabs are on an angle, this might also make mounting an aftermarket retractor difficult.  It seems most of the aftermarket retractors mount directly to a b-pillar or at 90 degrees from the floor with a "L" bracket.  This is shown here:
So I think retrofitting the front belts with a modern setup might be difficult if I want to use the factory seat belt mounts (which I do).  I am wondering if I send my stock setup to a seat belt company if that can alter it and install a new retractor assembly in the existing setup.  That might be big dollars though.
Anyone have any thoughts on the front belts?
I think for the rear, I am leaning towards going with a retractor mounted on the package tray, and a custom bracket below the shelf to reinforce the tray like the Chevelle guys use.  The 4 points would require two more shoulder strap mounts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-October-2017 at 11:24AM
vince, that's what i was saying... i have several of those brackets for the lower mount from a 74! they are just spot welded up in the rocker, all you'd need to do is remove the spot welds from yours, cut the slot a little longer, and put the 74 brackets up in place and plug weld them in just like factory  i'll check on the 4dr i'm parting it has separate retractors that might work for the rear???
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 21-October-2017 at 7:23AM
Thanks Johnny, I didn't know that's what you meant in your original response.  The only issue I have, is I can't weld.  My other concern is, I am not sure if the newer style Torino belts will work with the shoulder mount in a different spot.  It's definitely an option though.  How much would you want for them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-October-2017 at 8:10AM
i never paid much attention but maybe look at late model Crown Vic as to how they mount the rear retractors. they do have a 3rd middle seat winder on the package tray but the other 2 are out of the way behind the interior panels
maybe even graft the entire mounts & sheet metal into the Torino?
how bout a roller coaster safety bar? clunk you're locked in!
jessie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jessie Quote  Post ReplyReply Direct Link To This Post Posted: 20-March-2019 at 10:54AM
Hi Vince,
I'm from Paris France and I have the same issue, I'm looking for a rear 3 point seat belt for my 2 years and half son. I have a 73 fastback Gran Torino.
Have you found a solution, is there a shop selling it ? Did you customized something ?
Thanks
PS : Thanks to California Johnny who led me there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 20-March-2019 at 12:01PM
Jessie, no I haven't installed any belts yet.  When I do I will update the thread.  In the mean time, the only person who has is Sininenlll.  His car is the blue Torino seen partway up this thread.  You can copy what he did to do an install in your car.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 20-March-2019 at 1:05PM
Anyone used Seatbeltplanet.com? I was thinking 4-point in the middle of the back seat. Probably have to get creative in the trunk to add a cross brace under the tray.
Edited by handsofstone - 20-March-2019 at 1:06PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-March-2019 at 3:36PM
Originally posted by jessie jessie wrote:
Hi Vince,
Thanks
Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jessie Quote  Post ReplyReply Direct Link To This Post Posted: 21-March-2019 at 11:47AM
Thanks Vince/ @72FordGTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 23-October-2024 at 7:31AM
Vince, I am going to chime in here. Dragging up this older post.
When I was selling off Dave, my 1993 Mustang fox body, I kept a spare set of front belts.
I've wondered how hard it would be to adapt mustang belts, and place the retractor down in the front of the 1/4 panel and weld in a plate into the rocker panel structure. The rockers on our cars in places are 4 layers of steel sandwiched together.
This is a convertible fox body front seat belt mounting:
Only pause for concern would be the B pillar is for all purposes the same as a mustang convertible, with no post going all the way to the roof in the example of a GTS / Sportsroof body.
Formal roof cars are a bit better of structurally as they lack the larger quarter window area.
With that said...I'll be frank.
Our era of cars while they may be proverbial tanks on the 73+ battle ram bumper cars...the safety restraint belts in our cars are a horrible design in my mind.
72-73 Sportsroof upper seat belts are utterly worthless.
 Short of installing an impractical "tiger cage" type safety roll bar (modular system with better adjustability for most 2 door RWD American coupes like Torino, Chenille, Cutlass, etc...that messes up the rear seat access.
Primary reason my car never got a seat belt cage/bar is because I didn't want to mess up rear seat access. I've considered a Shelby style 3-point seat setup but never bothered. Ricaro makes a copy of the Shelby seatbelt trip-point system with a retractor, but again, never sure I wanted to mess with something like that as I am by no means an expert when it comes to safety placement of seat belts.
This design has a top retractor, but you have to have a roll bar hoop to mount this to behind the front seats.
Seems the least invasive to me and belt retractors allow movement.
Lower lap belt is a single mount point like 72-73 Torinos.
Again, I'm no expert but a constant thing hitting back:
I'd like to see belts that are shoulder level or higher to avoid crushing of the spine.
One of the issues I see with the fox body convertible seatbelts re is the upper point sits too low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 23-October-2024 at 7:37AM
Side note:
In case anyone needs a refresher on "reasons why I may drive like a maniac hot rodder, but still avoid everything at all costs..." Here is 1975 Torino crash test footage WITH seatbelts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 23-October-2024 at 5:51PM
The thing with the crash in the video is that it appears the front worked as a pretty effective crumple zone, but the seatbelts didn't hold the dummies back at all, turning minor injuries at most into potentially fatal head trauma. Modern belts with motion-activated locking systems would make a huge difference in this scenario.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 27-October-2024 at 1:10AM
Thanks for bringing back this old tread Andy.  I have not changed my belts, and I am running with the stock two piece belts and the lap belts in the rear.  I know they are not the best, but I also am not interested in modifying my car to run something like Fox Mustang belts. My car is pretty stock and I like to keep it that way. If I could swap in modern belts without any major modifications, I'd do it.  I know it would be a worthwhile safety upgrade.  The way I figure it right now, is I have to drive more carefully and accept the inherent risk to driving an old car.  Its no different that riding a motorcycle - you have to accept the risk to injury is much greater than driving a modern car.
On the crash test video, I thought the Torino did well for a car from this era.  Unlike earlier cars which may not crumple as much and have less damage, our Torinos at least had some engineering to absorb the energy of the crash. This is a good thing for the occupants, but of course means the car gets more damaged.  However, like Inkara said, the seat belts did a poor job, which is why I still think a modern upgrade could be beneficial.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 13-November-2024 at 2:58PM
Actually, the Torino seat belt retractors have the centrifugal activated setup. I know, I have had my belts lock before on a few instances of...ahem...my driving habits...
Face Troll GIF
I think overall the issue comes down to modification of either the rocker plate on the sill area of the Rocker panels. That plate is buried in 4 layers of steel sandwiched over 1/4" of steel. Not exactly easy to modify IMO.
Modifying the B pillar area is also a concern because the 72-76 cars are not post cars, like a fox body hardtop with a full B pillar.
Granted I've tried to consider the convertibles, but fox converts, that belt seems like it sits too low and would cause spinal compression in an accident.
Which them leads me right back to the darn thought process for a simple Shelby style trim-point belt setup. Tie a basic bar into the upper seat belt mount points on the roof structure but then you are still stuck honestly needing some form of tie bars to the rear of the car. Not an easy solution to solve.
