  New Posts New Posts RSS Feed - Sheet Metal
Sheet Metal
swampbug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swampbug Quote  Post ReplyReply Direct Link To This Post Topic: Sheet Metal
    Posted: 11-September-2015 at 6:00AM
Where do you guys buy sheet metal? I can only find small patch pieces and preformed body parts.
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2015 at 6:19AM
If you are going to weld the sheet metal onto your car, then it would be best to use a sheet metal that has the same exact thickness (gauge size), as the metal that you are going to weld onto.
To see a sheet metal seller click here.
To see another seller click here.
Edited by dave302 - 11-September-2015 at 6:20AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote swampbug Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2015 at 7:01AM
nice, second link has a local location, so I can pick up and avoid the 70 delivery fee. Just need to figure out what sizes I need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2015 at 11:59AM
it looks like the thinnest gauge they have is 16 ga. which is fine but a little thick. and stay away from galvanized, you can use it but you need to grind off the thin layer of zinc back about an inch, to be able to weld on it. FYI
