  New Posts New Posts RSS Feed - SOLD: Complete 1972-79 Four speed set up
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Topic: SOLD: Complete 1972-79 Four speed set up
    Posted: 17-June-2024 at 3:18AM
I have a complete 4 speed set up available for swap until I get to that point in my build. If I don't swap it, I will install it into my car.
NOTE: LOCATED IN NEVADA, TX.
Seeking: Rebuilt, and warrantied (if possible) FMX. (Alternatively $ required to attain same transmission without core).
No Shift knob, I only have the knob from my very first torino, I will be keeping that.
No Speedo cable.
Parts I am offering, all new unless stated:
  • 1972 RUG-BF 1 Top Loader, with Bell- David Kee Master Kit (seals, synchros, bearings, etc) installed with new 2nd and 3rd gears.
  • MDL Conversion pedal.
  • MDL Brake pedal pads.
  • New driveshaft yoke.
  • New shifter boot with trim
  • NEW reproduction Z-bar assembly with rods, mounts, etc. Complete.
  • 2.5" hole bellows seal for clutch rod.
  • Refurbished clutch fork, with new boot.
  • Throw out.
  • 11" clutch
  • SBF Flywheel
  • primered Automatic tunnel hump OR unfinished 4 speed hump with reverse light cable.
  • Original shifter, with a Hurst rebuild kit. (not installed).
  • Linkage hardware, new.
  • Floor shift steering column, refinished black, includes turn signal switch, no lever.
  • NiB Black formal roof carpet set for floor shift
  • If something's not listed here, I probably have it.
Edited by peter.jenerette - 17-June-2024 at 3:48AM
Booyah45828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Booyah45828 Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2024 at 6:20AM
Man that's a deal for someone.
I have to ask, why the fmx? The one I had in my 73 mustang worked well, but as a whole they seem largely unloved and undesired.
I've got the c4 that was included with my project, that was supposedly rebuilt with the converter still in plastic, but I doubt you're interested in that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2024 at 9:22AM
Mostly because that's what was original. (I actually have one in a parts car). I have never had an issue with an FMX in any car that i can recall. I have had poor experiences with a C6, and an AOD. It's also more about hunting down pieces to fit it. looking for correct pieces, such as levers, cables, cooling lines, etc. I would consider an AOD if it comes with ALL the pieces including at least a 3.25 28 spline 9 inch center section.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2024 at 4:00PM
My ‘76 Gran Torino 4dr that I had back in the late 80’s had an FMX……the trans went bad—lost 2nd gear. Had it repaired, and two weeks later, it lost reversed.  Had it repaired AGAIN, and after that, it didn’t go bad again……
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 18-June-2024 at 12:13AM
Only trouble I can recall ever having was the modulator going bad on a couple of them. This includes my Dad's vehicles.
The AOD I had trouble with was in a 92 Lincoln Mark VII LSC, the bushing went on the throttle cable which eventually burnt it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 18-June-2024 at 5:55AM
That AOD's TV cable is critical to the trans, those plastic bushings eventually fall apart, about 20 years is too long to expect them to last. Without the TV cable set right, the line pressure is way too low and it creates slippage. There is a metal replacement bushing, some trans part suppliers have it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 18-June-2024 at 6:05AM
Lesson was learned, I have a pack of the metal ones somewhere in the shop
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 29-August-2024 at 1:34PM
This is no longer up for Swap. It is all for sale. Only respectable offers will be considered.
Boss2man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss2man Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2025 at 4:19AM
I know your post is now almost a year old but I am thinking about converting my 72 Ranchero GT to a manual.  Do you still have these parts?  BTW, what is in the car now is a rebuilt C6 with a Gear Vendors overdrive.  Everything is all new, complete and never used.  I purchased the car as an abandoned project from the previous owner who had big plans.
LC Fordmercuryman
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2025 at 11:44PM
Yes. I do. It's now for sale, I have converted to a 4R70W
PM me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss2man Quote  Post ReplyReply Direct Link To This Post Posted: 02-April-2025 at 2:24AM
Have you sold this?
LC Fordmercuryman
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 02-April-2025 at 2:36AM
Originally posted by Boss2man Boss2man wrote:
Have you sold this?
You may not have seen his response above, but it is not sold.  I have upgraded you to a new member so you have full forum privileges now. You will be able to send him a Private Message to work out the details.
I do have one question for you.  You have a C6 with a gear vendors.  Does this fit the the car without having to modify the floor pan?  Do you have any pics of the setup installed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 29-April-2025 at 12:01AM
THIS HAS BEEN SOLD.
Thank you!
This page was generated in 0.150 seconds.
