  New Posts New Posts RSS Feed - Sound deadner
Sound deadner
smhj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smhj Quote  Post ReplyReply Direct Link To This Post Topic: Sound deadner
    Posted: 17-December-2011 at 1:38AM
Whats better the sheets or the spray? Also do both help with the heat if it's on the floor?
73MONTEGO
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Posted: 17-December-2011 at 3:19AM
I'd say sheets, but that's only me. Sheet and spay should work even better together, nut that's a lot of weight to had
mule323 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mule323 Quote  Post ReplyReply Direct Link To This Post Posted: 17-December-2011 at 5:24AM
I don't have any experience with spray on deadeners but I can say I'm pretty impressed with the press on. I used 80 mil and am verry happy with the results. It does a really good job at keeping heat out of the the car.
             (Steve)
73 G.T.S. Fastback, 351C, C6
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 17-December-2011 at 9:12AM
I agree the sheets are easy to work with too. No mess to clean up. Dead
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2011 at 12:58PM
Stuff they have is miles ahead of what was done when these cars were built.
Personally, I'd take the route of the Lizardskin spray on material, cleans up with water I believe.
Tape off what you don't want covered, and spray it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2011 at 3:08PM
Timely thread. Now that I have the body back on the frame I've started prepping the top side of the floors for paint. I wanted to go with the original sound deadner but it's in rough shape.
13 Taurus SHO "Mr Pig"
Post Options Post Options   Thanks (0) Thanks(0)   Quote mule323 Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2011 at 3:35PM
Unless you're doing a full concourse resto I wouldn't worry about using original sound deadner. Like Eliteman said, the new stuff is light years ahead of what they had back in the day. Either the spray on or adhesive backed will do a great job.
             (Steve)
smhj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smhj Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2011 at 12:47AM
Thanks for the info. I think I'm going with spray.
73MONTEGO
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2011 at 1:34AM
http://www.ford-trucks.com/forums/1113009-reduce-road-noise.html
Read that. I like the approach 74 SCS took with his truck. I am going to try this with my F100. If it goes well, I'll do my Cougar as well.
This page was generated in 0.656 seconds.
