  New Posts New Posts RSS Feed - Spacer Plate GRAN TORINO 73
jessie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jessie Quote  Post ReplyReply Direct Link To This Post Topic: Spacer Plate GRAN TORINO 73
    Posted: 09-July-2015 at 10:58AM
Hi,
I'm from France (Paris) I've bought a very nice 73 Gran Torino Fastback 351 Cleveland 2bbl, almost a year ago.
I need to replace my spacer plate, it's very used, tried ebay and rockauto but nothing...Impossible to find one for the moment, any suggestions please ?
Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2015 at 2:45PM
are you referring to the one under the carb?
welcome! post some pics of your car when you can Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2015 at 8:39PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote jessie Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2015 at 10:48PM
Yes the one under the carburetor
Post Options Post Options   Thanks (0) Thanks(0)   Quote jessie Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2015 at 11:27PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote jessie Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2015 at 2:07PM
Thanks for the links Rockatansky, but is it gonna fit for my 73 Torino (351 5,8 Cleveland 2bbl) ?
Not the gasket for sure, have a look :
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2015 at 2:35PM
that's what they do, either clog with carbon or erode & burn through... that one you have there will never hold a gasket for very long
as far as fitment you'll have t match up the pics as best you can, or try to go by the numbers. sometimes there are multiple part numbers that are basically the same & will work, or the same part but a different year thus a different number
this new plate just showed up, looks like it should work for you?
the vacuum nozzle sticking out can just be blocked off with a rubber cap & hose clamp if you have no use for it, if it's even machined open? it looks like the one I linked above but the hose connector is not present so it may be solid / not machined
here is one with the nozzle and the hose connection
Edited by Rockatansky - 12-July-2015 at 2:43PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2015 at 2:39PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2015 at 6:53PM
nice car! looks to be in near perfect condition Thumbs Up
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2015 at 10:43PM
I might have a 2bbl spacer plate at home......cant remember if I sold it with the carb or not, will check on wednesday when I'm back
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote jessie Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2015 at 10:55AM
Nice ! Thanks Nuggets !!
5,8L 351 Ceveland (73 Gran Torino)
Let me know !
Post Options Post Options   Thanks (0) Thanks(0)   Quote jessie Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2015 at 11:05AM
Thanks CaliforniaJohnny !
Yes it is, saw it on ebay 2 years ago, I've missed it, but the car was sold in France !! So I asked to the new owner if he wanted to sell it, and now it's mine !
The interior is near mint condition, never replaced, it's impressive.
albo74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albo74 Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2015 at 11:46AM
  OK so what I did was plane down the spacer plate to get a nice smooth surface , then   tap the exhaust  ports on the spacer and plug them off , lock tight ,  forget recycling emissions gasses , then use a gasket that was used prior to 72 , hooked every thing up to look stock ,  but no more of that dumping  un burned fuel and exhaust gasses  into the top of that engine . runs great .
albos73gts
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2015 at 2:42PM
^^^ i was going to suggest that. plugging off that emissions crap, that's what i do on all my cars. that egr plate was a stupid design IMO (just for this reason!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote jessie Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2015 at 3:29PM
Thanks Albo for your answer,
My english is not so good, so what do you mean excatly "tap the exhaust ports on the spacer" ?
And how do I plug them off ? With some material ?
I don't get it, sorry for this language barrier...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2015 at 4:04PM
Tapping means to cut threads into the hole so you can install a pipe plug.
Your EGR spacer has the part off the back for the backpressure transducer. Those parts usually rotted apart inside of five years. If you don't have emissions testing, get a solid spacer.
Montego View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Montego Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2015 at 12:48AM
Jessie has my old car over in France..  I've found him the correct spacer for the 73/74 351C / 400
He also needs the flex hose that attaches to the end of the snorkel on the air cleaner..
It was there when I sent the car overseas, but its gone now.
He doesn't need the plastic at the other end.. just the flex hose itself..
Anyone have one in good enough shape to use?
Here's the car in Nov 2013 a few weeks prior to departing the USA..
Edited by Montego - 16-July-2015 at 12:50AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2015 at 2:40AM
Not to be negative Nancy here, but I had a hard time finding one of these. Luckily I ran across one on Ebay fairly cheap.
I'm not  sure why the Autopart stores just don't carry them anymore. Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2015 at 3:04AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2015 at 8:12AM
Had a look, unfortunately its gone. Only thing I've got left is the manifold and no one wants them
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2015 at 3:52PM
^^^that bronco one should fit? says 66-77 i think most of the cars were the same in the 70's IIRC
Post Options Post Options   Thanks (0) Thanks(0)   Quote jessie Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2015 at 9:53PM
Thanks for your help Big Bird !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jessie Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2015 at 9:56PM
Hey Montego !!!
Thanks helping me !!!
The car's still the same, amazing ! I'll send some pics with the Eiffel Tower in the background as soon as everything is fixed !!!
Can't wait to drive this awesome car, she's sleeping in the garage...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jessie Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2015 at 10:15PM
Hi Nuggets,
Thanks for looking !
Post Options Post Options   Thanks (0) Thanks(0)   Quote jessie Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2015 at 10:18PM
Hi Rockatansky,
Looks the same, just need to know if it's the right size...I've tried to find some infos, but nothing about the size.
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2015 at 3:23AM
I checked on the Autozone page, 1975 Torino uses the same part as 1975 Bronco
I also came up with Dorman 96052 but that number is a dead end, these fresh air tubes may be going extinct
This product is a fit for your:
1975 Ford Truck Bronco 5.0L 2BL OHV 8cyl
Part Number: 96052
Alternate Part Number: P2516-25
1975 Ford Torino 5.8L 2BL 8cyl
Part Number: 96052
Edited by Rockatansky - 17-July-2015 at 3:30AM
