  New Posts New Posts RSS Feed - Speedo cable
Speedo cable
RAPTOR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RAPTOR Quote  Post ReplyReply Direct Link To This Post Topic: Speedo cable
    Posted: 21-January-2016 at 4:27AM
I need to replace the speedo cable . I found some Original ford OEM ones   . My question is was there different lengths on 72 . I found  a couple  of these for sale Cable D2OZ-17260-B  it fits options with 3-speed manual transmission, C4 automatic or FMX Cruise-o-matic .
I have a 4spd  what would be the Difference on 3 spd ? Shouldnt it  hook up on the same side off gear box ? Why wouldnt it work ?
1972 Torino Sport 4Spd Q 351c
1996 Bronco XLT
2010 SVT Raptor
2003 H2 Hummer
1977 CB 750 Cafe Racer
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-January-2016 at 11:59AM
i think the 4spd and the fmx auto are the same??? are you wanting an NOS, or would a perfect used one be ok? i have the one out of my 74
75GranMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 21-January-2016 at 12:30PM
i'd have t do some checking to be positive, but I almost certain the 4spd and C6 are the same cable.
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2016 at 7:50AM
4 SPEED IS LONGER AS IT GOES IN ON THE PASSENGER SIDE.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RAPTOR Quote  Post ReplyReply Direct Link To This Post Posted: 26-January-2016 at 8:03AM
OK so the 3spd manual is not on the same side its on the driver side for hook up .
 Thanks michael .
I never look at a 3psd so i never knew that .  So it would be to short for a 4spd
Edited by RAPTOR - 26-January-2016 at 8:29AM
1996 Bronco XLT
2010 SVT Raptor
2003 H2 Hummer
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 27-January-2016 at 7:19AM
CHUCK,
Not sure where the three speed goes in, I'd assume passenger side.  the C6 cable is about 72" long, it may work but i "think" its a longer cable because it goes across the firewall, above the bellhousing and then down and under. I remember when I pulled mine thinking "thats a LONG sumbitch!". Lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2016 at 1:23PM
D2OZ-17260-D is the correct part number for 4spd and c6 applications. I'm in the hunt for another one myself .... bent mine when I broke the output shaft the other day.
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2016 at 2:00PM
Bent the output shaft? What happened?
72GTS Clint Eastwood Special
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 10-October-2016 at 2:03PM
No, I broke the transmission 28 spline output shaft. Power shifted second, she hooked up real good and snapped the output shaft in two places in the tailshaft housing, right behind the rear case bearing and right in front of the output shaft splines for the drive shaft yoke. when it broke it busted both plastic speedo gears and bent the metal part of the speedo cable housing. Should be back on the road by this weekend.I upgraded to a 31 spline output shaft and drive shaft slip yoke. Had to machine the rear tail housing to accept the bigger yoke, I ordered a new NOS speedo cable from Miller Obsolete ford parts Binghamton NY $46 plus shipping. It was the first time I really got on it too. I real should grow up....Nawh!
