  New Posts New Posts RSS Feed - Speedometer Cable (4 Speed swap)
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Topic: Speedometer Cable (4 Speed swap)
    Posted: 22-May-2024 at 8:52AM
Hi All,
Will be performing a conversion to a top loader (i have all the parts, and will be using the MDL pedal).
The only open item I have is the speedometer cable. (I know about and have the proper speedo gear).
Will the existing FMX cable make the stretch to the opposite side, or do i need to source a replacement. If i need to replace, does anyone know the appropriate length?
I went through the forums, but didn't see anything definitive on the swap.
Thanks ahead of time!
This page was generated in 0.114 seconds.
