Sport mirror mounting ferules. |
Anderslober ![]() Senior Member ![]() ![]() Joined: 30-July-2019 Location: Denmark Status: Offline Points: 319 |
![]() ![]() ![]() ![]() ![]() Posted: 05-August-2022 at 5:27AM |
Hello forum. I want to mount sport mirrors on my car. On which side of the door does the ferule go??
From the inside and up? Or from the outside and down? My thinking is, if it is from outside down…nothing is really holding the mirror down to the door…..
67gt5003119 ![]() Senior Member ![]() Joined: 09-December-2012 Location: Gig Harbor Wa. Status: Offline Points: 477 |
Ford used a 'nutsert' to mount mirrors and other exterior items. It takes the correct size ferule and a special tool. Nutsert is inserted into the hole from the top and, using the tool, pinch or collapse the nutsert on to the metal
Ok…are these nutserts and tool available? Or are equivalents available?
I have a Scott Drake mounting kit, but the inserts are soft rubber…that wont hold much….
I found the tools and stuff……probably a good idea to do that!
Greg73Oregon ![]() Member ![]() Joined: 23-February-2021 Location: Roseville, CA Status: Offline Points: 114 |
I bought mine at Harbor Freight. Came with an assortment of nutserts.
GKF
