  New Posts New Posts RSS Feed - Sport scoop graft & 72 Sport hood reskin
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: Sport scoop graft & 72 Sport hood reskin
    Posted: 13-April-2012 at 3:17AM
i'm going to be doing the famous 72 Sport hood scoop graft onto a 73-76 Gran Torino hood
and was going to do a progress thread on it and also take some video's too.
I know some have seen photo's of the scoop graft from Eliteman76(Andy) and also Uante(Brent)
but no one has done a step by step procedure for it an no one has taken video's of actual
 work being performed so since I will doing this project I though I might as well document it for others so they can see how it's done and those with welding experience can try it themselves
*EDIT
I also will be reskinning my original 72 Sport hood and replacing the complete bracing from a donor Sport hood that has good bracing but some rust on the outer skin at the rear corner edges.
this thread will contain 2 hood projects now
The 72 scoop graft onto a 73-76 Hood and also the 72 Sport hood reskin
Edited by 72 GTS 429 - 28-May-2012 at 2:06PM
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 13-April-2012 at 9:12AM
First step is more of restoration process as I will be stripping off all the old paint and get the hood surface down to bare metal as I want a fresh canvass. after i get the hood stripped and deal with any surface rust which I treat with Muriatic Acid which will eat into the metal and dissolve any minor rust.Then I neutralize the acid with water and dry it with compressed air and then apply
phosphoric acid to coat the metal against flash rust while I work on it till it's ready for primer.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 13-April-2012 at 2:06PM
ok I might as well just make this a start to finish project as you will learn other things besides just welding on the scoop.
Here is the 73 GranTorino hood i'm using for this project
some surface rust where the paint was missing(don't worry this will clean up good)
surface rust where paint was thin on bodyline
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 13-April-2012 at 3:01PM
First step is to strip the paint off
The car the hood came from had one repaint so it has a layer of most
likely Enamel paint then the original lacquer paint underneath.You can use chemical stripper to remove the enamel but it doesn't work well for the old lacquer paint and makes a mess as it makes
the lacquer turn to liquid so it gets messy.The enamel will wrinkle up from the chemical stripper and dry out so it's easy to just scrap off but I prefer to machine sand it to bare metal when working with old lacquer paint.
For this I choose a good work horse,which is a 8in Orbital sander
this is my trusty National Detriot Model 900 which I have had for 25 years.
there are other brands  but I have had this since early in my career and it works great for eating up the paint but it uses alof of cfm's so you need a big compressor.
I first start with 36 grit paper but I let the sandpaper do the work and not force it down on the hood.
I only try to take the layers of paint off down to the factory primer and not keep sanding to get it to bare steel as you don't want the 36 grit scratches in the metal.
here it is down to the factory primer with some bar spots which is fine just stop once you have the color removed.
close up of factory primer left
here is a close up of the surface rust after sanding,don't worry looks worse then it is
 here there was some minor rust holes in the front edge on either side of the hood
I will cut out the bad spots and weld patches in so it doesn't return
This is some minor surface rust that I can clean up one of 2 ways
either I can lightly sand blast it with a spot blaster or I can use the muriatic acid to dissolve the rust and clean the metal.
Ok now I switch to 80 grit on my 8 in orbital sander to remove the factory primer and take it the rest of the way down to bare metal.Warning, do not sand in one spot too long as it will heat up the metal and can cause warping. Use fresh paper if it stops cutting as good as the metal dulls the sand on the paper.Move around especially on the middle where there are no braces underneath.Let it cool and sand another area and come back if you need to sand further to remove the primer.The orbital sander will leave traces of primer but get 90% of it off
looking at the hood the left side has been sanded down with 80 grit and the right still has the primer left from sanding with the 36 grit
here we have some old bodywork which I will remove the body filler
Here I have removed most of the filler and the tip of the blow nozzle points to the dent at it's deepest point.This will be repaired with a stud gun puller later.
back in the day they use to drill 1/8th in holes and use a screw puller to pull the dents out
but whoever repaired this hood just filled it.Good thing as no holes to weld closed but now
I can do a proper repair and pull the low spot out with a stud gun puller and have only a skim coat of filler to make it smooth.
here I lightly sandblasted with a spot blaster to see how deep the surface rust was
and it cleaned up well so i stopped as I will be treating the hood with muriatic acid and it will remove the rest but notice the dark color rust has mostly been removed with a quick blast
before
after
Now we switch to 80 grit on a 6in DA sander to remove any traces of the primer that the orbital didn't remove
Edited by 72 GTS 429 - 13-April-2012 at 3:11PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 14-April-2012 at 3:53PM
Very informative. I like it.
72BlackGTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72BlackGTS Quote  Post ReplyReply Direct Link To This Post Posted: 15-April-2012 at 1:51AM
The process is very time intensive. Jeff, how long did it take you to do the whole process in those last pics? Just to give the guys who don't know a time frame. Good thorough explanation. Good job.   Ron
Ron
1978 LTD II Sport-Green
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 15-April-2012 at 2:50AM
well it took longer cause the compressor I have now is a 3hp 60gal tank wih 135psi max and it doesn't recover as fast.Like I mentioned the 8 in orbital uses alot of cfm's.When I had my 5hp 80 gal 175 max psi compressor I could just keep sanding and not stop and let the air build up.
I didn't time anything but the red paint came off really fast with the 36 grit and maybe took 15-20 mins.
when machine sanding it will take time but your not in a race as you don't want to cause too much heat to the metal and warp it.Hood,trunklids and bigger panels flex when you sand them cause there are are's with no braces behind the sheet metal and that is where you have to be careful not to sand in one spot too long as the metal builds up heat and warps but if it's not to much heat it tightens back up when it cools but that is why I skip around from side to side so I don't cause excessive heat to the metal.
 believe me chemical stripping is no faster and is a mess.The only thing that is fast and is not cheap to do is plastic media blasting or soda blasting,but you have to take it someplace and pay to have it done.
75GranMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 15-April-2012 at 1:57PM
Jeff,Awesome how to project,body work is the one aspect of auto repair that I never had the need to master.For 25 years at the ford dealership,my close friend Wayne preformed all my repairs.As he's the guy painting my current torino.can't wait to see the hood! most all the hoods around have the same rust on the front lip area.hows the bottom side for rust?
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 15-April-2012 at 3:37PM
bottom side is good just minimal surface rust that will clean up nice.
i'll post some photo's tomorrow as i'm gonna start sanding the underneath.
This hood that i'm building here is going on John's(75GranMan) car
which he is doing the S&H stripe on the darkred  instead of 2B as his car is originally the darker red
and wants to be different.
This hood will make a great addition to your car John
srwith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote srwith Quote  Post ReplyReply Direct Link To This Post Posted: 16-April-2012 at 10:24AM
Just sanding is all you had to do for this surface rust?
two loves, torino's and bike riding. drive and ride safe.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 16-April-2012 at 12:24PM
it's still there but looks better when it's stripped down to bare metal.
the Muriatic Acid will remove what traces of the surface rust is there.
When I stripped my 72 GTS before I primed it I coated each panel with muriatic acid
 to remove the surface rust and the slight pitting and it cleans it out good.
You have to neutralize the acid so it don't keep eating at the metal so I rinse it with water
real good then dry it with the blow nozzle from the compressor.
It will started turning brown after that so you then have to coat the bare metal
 with phosphoric acid which you can buy at Home Depot and that will eliminate
the flash rusting and you just let that dry so it coats the metal and protects it.
   Before priming I sand the residue from the phosphoric acid off with 80 grit on
a 6in DA Sander then I wipe it down and prime it.
If you want to use 2K urethane primer surfacer you first have to prime the bare metal with
self etching primer and I will show that later in the progress.
Edited by 72 GTS 429 - 16-April-2012 at 12:36PM
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 16-April-2012 at 12:31PM
Here is the underside of the hood John, I started cleaning it up with a wire wheel and alot of the old paint was coming off as it was all original underneath.I did take a spot down with roloc scotchbrite surfacing disc and the metal is great under the paint and primer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 16-April-2012 at 1:49PM
Jeff,I have a spare hood that I have in storage,I know it has some rust on the bottom side brace area, not sure what side the rot is on,If you need to patch in pieces.I can check and sent pix if you want.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 16-April-2012 at 1:56PM
the only rust is right here on the front round indention that is stripped bare
it would be the driver side when on the car.
The rest is perfect just need to strip off all the old paint and primer so  I can start fresh
Edited by 72 GTS 429 - 16-April-2012 at 2:12PM
picon3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote picon3 Quote  Post ReplyReply Direct Link To This Post Posted: 16-April-2012 at 2:34PM
Jeff,
Fantastic thread.  Keep the details and pictures coming!
Paul~
1972 GTS 351CJ-4V black/black
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 16-April-2012 at 2:50PM
yah this is the boring part cleaning it all up to start fresh.The fun begins when I start cutting the hoods for the scoop graft.I figure I might as well show it all as people can learn from it
papadeath View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote papadeath Quote  Post ReplyReply Direct Link To This Post Posted: 17-April-2012 at 7:44AM
I have to add something: Water alone will not stop the acid completely, it just dilutes it. Of course, continued rinsing will eventually disperse it I reckon. However, to truly neutralize it, you need a 'base', such as sodium hydroxide, or lye, probably most drain cleaners will work if they don't have too many other additives.  Easy Off used to be lye based, but they changed the formula and now it's crap, hehe. Thanks for the wonderful how-to.!!
75 Ranchero in progress
04 Harley Deuce stage one kit
89 Toyota pickup modded
skateboard
4 bicycles
1 scooter
2 dogs
2 stupid cats
Post Options Post Options   Thanks (0) Thanks(0)   Quote papadeath Quote  Post ReplyReply Direct Link To This Post Posted: 17-April-2012 at 7:48AM
Oh, by the way, be careful welding on that thin metal! I welded a little scoop on my Toyota and it warped my hood, gak. No biggie, just my work truck. Still looks cool, though. I have one question; You know the space between the reinforcement bars/skeleton on the underside of the hood and the actual hood? When the factory spacers, glue, whatever they used to keep the hood from rattling, what do people use to replace it?
skateboard
4 bicycles
1 scooter
2 dogs
2 stupid cats
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 17-April-2012 at 9:59AM
3M makes a special 2 part product for that but it takes the special application gun to use it and they are not cheap.The stuff that is on the hood i'm working on actually looks like  auto body seam sealer and what I use to use before they came out with the Dampening Material
3M™ NVH Dampening Material 04274
3M NVH Dampening Material 04274
Product Description
NVH Damping Material 04274 is a flexible adhesive-type material used to reduce noise and vibration between panels where a long work time is required. NVH Dampening Material can be applied between roof skins and roof bows, door skins and door intrusion beams or other areas using non-structural type foam materials, providing up to 1” thick layer of flexible material on vertical and overhead applications. 04274 can be applied to a thickness of 1 inch on vertical and overhead surfaces. It can also be applied over existing damping material as long as the original material is still integrally bonded.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 17-April-2012 at 10:58AM
btw thanks for the tip on neutralizing the acid,I just flushed it good with water then I apply the Phosphoric acid.
 welding sheet metal the process is the same on a hood or a quarter you have to weld a little at a time and skip around and let the metal cool every so often,it's a long process but this way you don't warp the panel too bad>You might get some slight warping but if you do it correctly the body filler should smooth it out or sometimes take a hammer and dolly to straighten it if needed but I try to weld  like small tack welds here and there and skip around then let it cool then start again and repeat the process till the seam is total filled in with weld.then you have to carefully grind the welds smooth as the heat from grinding can warp it so sometimes you have to grind a little at a time and let the metal cool in between grinding
 these grinding wheels on a die grinder help with grinding welds faster and keep down the heat but still have to let cool on big panels
3M™ Green Corps™ Reinforced Weld Grinding Wheel 01991
3M Green Corps Reinforced Weld Grinding Wheel 01991
Post Options Post Options   Thanks (0) Thanks(0)   Quote srwith Quote  Post ReplyReply Direct Link To This Post Posted: 17-April-2012 at 11:18AM
Jeff, I have a 72 hood with a scoop on it on hold when I get home. The guy live's about 3mi from my house. Have not seen it yet other than a picture of the top. It was on craig's list. I will be watching this post real close if I decide to do this on my own. The one your doing is the one I missed having you do for me.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 17-April-2012 at 11:28AM
is that the hood that I sent you the Craigslist ad for?
 yah if I stayed in Florida this hood would probably have been built for your car but unfortunately I had to move out of state.
there are a few guys that have done it or had it done.I have copies of the one that Andy did
but that doesn't give you a step by step like i'm doing here and plan to include some video's
once I get to the scoop part so this will be good for others who are interested in doing it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 17-April-2012 at 3:34PM
Jeff,here's some pix of my spare hood being sectioned for the project.I made sure to cool the panel with a damp towel to prevent warping.will send you section piece tommorow, if I can buggout for a few minutes.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 17-April-2012 at 3:48PM
hey wait that's the wrong side
just kiddingLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2012 at 3:04PM
No problem,I'll just send the big piece then!Wink.... you may have it by the weekend.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2012 at 3:38PM
yah shouldn't take too long to get to NJ
no progress today as it was rainy off and on,I miss having a garage to work in
Edited by 72 GTS 429 - 18-April-2012 at 3:38PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote srwith Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2012 at 1:41PM
Jeff that is the one you told me about. Will see it when I get home if he does not sale it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote papadeath Quote  Post ReplyReply Direct Link To This Post Posted: 23-April-2012 at 8:32AM
So 72 GTS 429 I have to buy an applicator with this product? I can't finagle it artistically? Thank you I will go looking for it. Do you know where to get it?
skateboard
4 bicycles
1 scooter
2 dogs
2 stupid cats
Post Options Post Options   Thanks (0) Thanks(0)   Quote papadeath Quote  Post ReplyReply Direct Link To This Post Posted: 23-April-2012 at 8:37AM
I'm so freaking stupid. Looking at this made me realize I can fix the buckle in my hood just by grinding on the scoop, duh.
Sometimes it takes me longer to figure things out, but when I do I feel like a genius, hehe.
skateboard
4 bicycles
1 scooter
2 dogs
2 stupid cats
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 23-April-2012 at 11:52AM
no cause the mix has to be right and push the 2 sides of the tube even so it takes a applicator gun to dispense it.I get it from the auto paint supplier as most carry 3M products but there are some online auto body supply companies just have to check to see if they carry it.
This page was generated in 0.244 seconds.
