  New Posts New Posts RSS Feed - Starting after long storage
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: Starting after long storage
    Posted: 24-August-2003 at 10:50PM
Does anybody have any tips for starting up after the car has sat for a long time.  I finally have some time to start restoring my old '74 Gran Torino Elite.  I went to start it yesterday after recharging the battery.  The starter grinds but it can't get the engine to turn.  The oil's in good condition, as I changed it right before I put the car away.  I seem to remember somebody in a similar jam taking a wrench to his crankshaft and turning it manually just to break it free and spread some oil around.  I don't know where to apply the wrench, though.  Any advice would be appreciated.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2003 at 6:55AM
Right in the middle of your bottom pully(the one with the harmonic balancer attatched to it), there is a 3/4??13/16?? inch bolt that you can get a ratchet and a cheater bar on and turn the motor clockwise thats the way I turned mine while putting in a new flywheel. Might build up some compression maybe loosening a few spark plugs will help.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 29-August-2003 at 8:55AM
i would change the oil again it breaks down just sitting there in the oil pan and squirt a few drops of  oil in each cylinder before you rotate the engine by hand sometimes the rings will seize to the cylinder walls which will crack them itll smoke for a little bit but its worth it if you save the rings depending on how long it set your gas may be bad also it has a tendancy to turn to varnish quickly
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 16-September-2003 at 6:02PM
Thank you both.  I'm going to change the oil and squirt some in each cylinder, then try to turn it by hand, then try to start.  If that doesn't work, do you think it would be wise to squirt some WD-40 in each cylinder?  If the gas is bad, what's a practical way to drain the tank?  I'm afraid the tank is fairly full, so disposal will be a pain.  I swear if I get this thing started again I'm never going to let it sit more than a week again.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2003 at 8:25AM
well the wd 40 i would not try.. just a few drops of motor oil or tranny fluid would work just fine .and just pull the coil wire off and leave the spark plugs out and crank it for a few seconds this will distrbute the oil around the cylinder walls and reprime the oil pump. it will crank alot faster with no plugs in it and sholud pump thge gas back to the carb.then put the plugs back in and the coil wire on and give her a couple shot of starting fluid and see if she fires up.  does the gas in the tank smell like gas or more like varnish? if its got a gas smell its probably still good. good luck
77LTDII View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77LTDII Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2003 at 6:21AM
I had a old 77 LTD II with a 351 sit in the barn for 6 years, and since my Ranger couldnt manuver it out it had to go under its own power, all I did was pump the gas, turn the key and pray. I wouldnt worry too much about it seizing up, givin the oil pump is in working order.
later
Dustin
This page was generated in 0.100 seconds.
