  New Posts New Posts RSS Feed - starting issues
starting issues
MusicMan21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MusicMan21 Quote  Post ReplyReply Direct Link To This Post Topic: starting issues
    Posted: 28-August-2015 at 3:38AM
I have a 1971 ford torino. I replaced the starter a few days ago and it started up and worked fine. Yesterday it wouldn't start. The starter solenoid was clicking but sparks were coming from where it connects to the starter. I replaced the solenoid and it no longer sparks but the starter still won't kick on. I've checked all the connections from the battery to the solenoid and from there to the starter. I've cleaned them all and made sure they were tight. I'm out of ideas and realy need my car to work. Willing to try any ideas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 28-August-2015 at 11:03AM
Take the starter off and bench test it or take it back to where you purchased it and have them check it. Autozone and Advanced Auto will check them for free. May have got a bad starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 28-August-2015 at 5:20PM
^^^todd's probably right.
but also check your ground cable, it usually bolts to the block, also check the ground wire from the engine to the frame/body
antlerfiend View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote antlerfiend Quote  Post ReplyReply Direct Link To This Post Posted: 29-August-2015 at 2:07AM
X2 on what Johnny said
This page was generated in 0.064 seconds.
