  New Posts New Posts RSS Feed - steering adapter?
steering adapter?
69fastford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 69fastford Quote  Post ReplyReply Direct Link To This Post Topic: steering adapter?
    Posted: 21-September-2006 at 3:35AM
Smile  Has anyone used the power to manual steering adapter? .seems like it would be alot easier than converting the whole steering setup.also would the one for the mustangs be the same? thanks for any help   mark
torino390 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torino390 Quote  Post ReplyReply Direct Link To This Post Posted: 17-November-2006 at 10:09AM
hi mark.
i converted the valve itself into an adaptor by shimming out any end float of the ball joint and removing the long thru-bolt. it's a bit fiddly to do but it saves you $$$.
the steering is heavy to park but a lot more positive on the road.
a friend of mine has a mustang with an identical valve fitted, so i assume they are the same. i would not be surprised to see the same valve on quite a few fords/mercs of that time.
i would like to change the whole set-up to rack and pinion but have no idea what parts are used.
good luck.
nick.
