  New Posts New Posts RSS Feed - Steering Upgrades?
Steering Upgrades?
Hinmaton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hinmaton Quote  Post ReplyReply Direct Link To This Post Topic: Steering Upgrades?
    Posted: 27-May-2025 at 12:50PM
I just determined that 60%+ of all my steering joints are shot.
It’s a 71Torino 500 with power steering and power brakes.
Where is the goto place for these parts? Are there any upgrades or improvements to be had in this area?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 28-May-2025 at 3:37PM
There are some disc brake conversion kits to upgrade your brakes:
Or performance oriented kits:
For steering parts, I have used Moog in the past to rebuild front ends, but I don't know if they are the same quality they once were.  PST offers kits too.
Lares offers a faster than stock steering box:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hinmaton Quote  Post ReplyReply Direct Link To This Post Posted: 30-May-2025 at 5:26AM
Thank you so much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hinmaton Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2025 at 3:33AM
Do you or does anyone else know if the two control valve hoses are identical and if the ones that came on the Mustangs and other models are all the same?
Post Options Post Options   Thanks (0) Thanks(0)   Quote schufitz Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2025 at 3:57AM
Check with these guys:
They specialize in front brake, suspension & steering parts for Mustangs & mid-sized Fords.
I used Moog & Scott Drake for parts when I redid my stock front suspension (control arms w/ball joints, tie rod ends).  I used some roller spring perches from e-bay.
Edited by schufitz - 02-June-2025 at 4:22AM
pyntre View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2025 at 4:58AM
Nice job on that suspension rebuild !
That’s the way to do it !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hinmaton Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2025 at 7:56AM
Wow! That looks fantastic. What is that lower spindle? Mind ballparking what you spent on the parts alone?
Post Options Post Options   Thanks (0) Thanks(0)   Quote schufitz Quote  Post ReplyReply Direct Link To This Post Posted: 04-June-2025 at 3:08AM
Thanks.  The spindles are factory, just cleaned up with brass brushes and degreaser.  I bought the items 'piecemeal' over a period of time and finally tackled the job last summer.  I probably spent close to a grand all added up.  That includes the roller perches, the SD lower arms (they have the 'tabs' and silver paint), an internal spring compressor tool, joint breaker tool & pickle fork for the ball joints.   I got Detroit Eaton springs but used the originals as the DE ones seemed too 'beefy' and would have most likely worsened the reverse rake the 68/69's seem to have.  Full kits are available a bit cheaper as noted in a reply above, but piecemeal is just the route I went.  Good Luck in whatever you decide.   I did get PS hoses from Choko-stang and the ram & valve, but have yet to tackle that project.
Edited by schufitz - 04-June-2025 at 3:18AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hinmaton Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2025 at 7:27AM
Did you build your internal spring compressor or purchase it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote schufitz Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2025 at 7:34AM
E-BAY purchase
dan0R30 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dan0R30 Quote  Post ReplyReply Direct Link To This Post Posted: 08-November-2025 at 9:53AM
I also bought that one from eBay. So worth it.
Dan
