  New Posts New Posts RSS Feed - Storing a Top Loader?
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Topic: Storing a Top Loader?
    Posted: 18-November-2024 at 3:29AM
Hey Guys,
Looks like I'm going to have to put all my 4 speed conversion parts into a longer term storage, before I do, does anyone have any recommendations on how best to store the top loader?
I know sitting, even in closed weather proof storage, that condensation will build in the case, so, I would like to prevent this somehow.
Open it up, Fog everything? Over fill it? other ideas?
Thanks!
Booyah45828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Booyah45828 Quote  Post ReplyReply Direct Link To This Post Posted: 18-November-2024 at 5:50AM
I did nothing with mine. I figured oil splashed around inside from use would have coated everything to prevent any condensation. When the buyer removed the cover to inspect, it looked no different then when I rebuilt it 8 years prior. If you're worried about it, I'd seal it with one of those vacuum storage bags people use for pillows and bed comforters and such. Sealed tight and it shouldn't have any issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 20-November-2024 at 12:25AM
Was yours stored in a climate controlled location for those 8 years?
This one has never been run since rebuilding it, and when I opened it up when first acquired there was light rust forming on some of the gears. (I don't know how long it was sitting, or the conditions). But, it is safe to say that some of the gears and shafts have never been heated from use while being splashed/immersed in oil. I imagine the assembly grease will protect the roller bearings.
Just think I will be storing this for a while, and would like to preserve its current state.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Booyah45828 Quote  Post ReplyReply Direct Link To This Post Posted: 20-November-2024 at 5:42AM
No it was in the loft of the shed. No heat or AC out there.
It was actually never ran in a vehicle, just driven with a cordless drill and appropriate sized socket on the input shaft for a minute or two. Did this right after rebuild because I wasn't going to use it right away and didn't want anything flash rusting.
If you have rust, you'll have to do something regarding that, as no oil or sealing up will prevent that from getting worse. Use your judgement on the rust and how light it actually is, then seal it up with a few moisture absorbers found at your nearest big box hardware store. I've also heard sidewalk chalk will absorb moisture and prevent rust too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 23-November-2024 at 12:46PM
Think of how many units sat in junkyards and back yard sheds forever and were fine all these years later. No need to overthink it.
