  New Posts New Posts RSS Feed - Stuck Distributor
Stuck Distributor
sabatona View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sabatona Quote  Post ReplyReply Direct Link To This Post Topic: Stuck Distributor
    Posted: 24-June-2012 at 12:01PM
Hi all.
I have a 351C 4V and the distributor base is stuck in the block.
I need to get it freed up so I can adjust the timing.
I do not want to pull the motor apart, just want to get the distributor broke loose.
I have saturated the base with PB blaster and have run the motor quite a few times hoping the head would allow the PB to penetrate.
I  have tried tapping on the base, so far no luck.
The stay bolt and triangle plate are loose, just not the distributor...
Any suggestions on how to get it broke loose would be greatly appreciated.
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2012 at 12:11PM
use this http://www.autozone.com/autozone/accessories/OEM-FWD-Axle-Puller-Adapter/_/N-26vd?itemIdentifier=2061_0_0_&target=shelf   and a slidehammer.  its what i ended up havingoot use on my cleveland.  it did the trick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sabatona Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2012 at 1:25PM
thanks for the link, i will give it a try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sabatona Quote  Post ReplyReply Direct Link To This Post Posted: 02-July-2012 at 1:51PM
Got the distributor loosened up. Had to remove the AC pump and upper radiator hose so I could get a good grip on the distributor housing. Now I am painting everything I had to take off before reassembly.
This page was generated in 0.072 seconds.
