  New Posts New Posts RSS Feed - Tag numbers Casting number tailshaft number
SEKCOBRA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Topic: Tag numbers Casting number tailshaft number
    Posted: 03-March-2024 at 10:12AM
Anyone have a factory 72 GTS with a 4 speed and know the tag numbers, casting numbers on the case and tail shaft?
Thanks
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
94 MUSTANG 5.0 LX NOTCH
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
64 Galaxie country sedan
1972 GTS Q CODE
1972 GTS Q CODE BLACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-March-2024 at 1:50PM
all that info can be found on the David Kee page under ID charts
the box i got with my 72 is tagged RUG-AR1 IIRC, listed as a 1971
the tail is D0ZR with the 3 front bolt holes tapped IIRC
from what i can tell my main case is D2AR-7006-CA, 1972 casting used in late 71
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2024 at 12:43AM
No tail shaft info there. Thanks for the heads up anyhow.
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2024 at 3:34PM
This page was generated in 0.133 seconds.
