Talladega engine removal? |
Post Reply
| Author | |
Rosedalenative
Joined: 14-January-2024 Location: Florida Status: Offline Points: 2 |
Quote Reply
Topic: Talladega engine removal?Posted: 08-October-2024 at 3:13PM |
I have a Talladega, runs great, no issues, but trying to replace a leaky oil pan gasket. I know the engine has to be raised a few inches. I removed the 8 bolts holding the two side motor mounts to the frame. I also removed the big nut in the middle of each. Engine doesn’t move. What am I missing?
Quote Reply
Posted: 09-October-2024 at 11:38AM |
pics of the 428 motor mount show 3 bolts to the engine and 1 nut that should release the engine from the chassis, not sure what the 8 bolts you're referring to are, can you post pics? |
SEKCOBRA
Joined: 27-November-2012 Location: NY Status: Offline Points: 674 |
Quote Reply
Posted: 10-October-2024 at 9:57AM |
Transmission
69 Mach 1 70 TORINO COBRA 71 TORINO COBRA 72 Z28 CAMARO 94 MUSTANG 5.0 LX NOTCH 72 GTS Q CODE 61 Galaxie 427 62 Galaxie 406 64 Galaxie country sedan 1972 GTS Q CODE 1972 GTS Q CODE BLACK |
Post Reply
| Tweet |
