Temp sensor |
Sonnydgt
Member Joined: 19-September-2006 Location: United States Status: Offline Points: 48 |
Thanks(1)
Posted: 23-June-2020 at 7:43PM |
Are there any other water jacket spots on a H code Cleveland Other than the factory spot. I want to install a second set of electric gauges. Oil pressure not a problem.
68 Mercury Cougar Convertible
72 Sport Fastback |
some had the taller water necks those had a couple plugs that could be removed and sender put in there...
do you mean the forward facing port just below the thermostat for the 'factory spot' ? you can use the threaded port in the water pump where the thermovac switch was originally |
Sonnydgt
Three good options, will pursue when I get the AC finished up. Thanks for the help
72 Sport Fastback |
The Torino Kid
Senior Member Joined: 23-November-2003 Location: United States Status: Offline Points: 250 |
would the water pump outlet temp vary greatly if use instead of the block location?
1973 Gran Torino Sport CJ 351
'Q' code 63R body |
72 RS 351
Thanks(1)
The outlet is at the top, the thermostat. So anywhere in that area the coolant will be close to the same. Much outside the outlet of the thermostat will show a good bit colder when the engine is cold and hasn't warmed up yet(T'stat closed).
