  New Posts New Posts RSS Feed - The Engine Compartment Dept.
Spoiler II View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spoiler II Quote  Post ReplyReply Direct Link To This Post Topic: The Engine Compartment Dept.
    Posted: 30-June-2014 at 2:53PM
Okay fella's here's a question that's crossed all our minds...
Your engine compartment.
Have you "spray bombed" it to be decent?
What have you done to make it show worthy?
Do you keep your hood closed at the shows?
Reason why I ask is I have a line on a orig 88,000 mi Montego with a standard 40 yr old engine compartment. Dirty, grungy...Has a 351M 2bbl with ice cold air, perfect interior, no rust.....thinking of buying it for my Cyclone Sportster project.
What I thought was taking out that engine with the nice rebuilt high hp 302's you see on e-bay to be show worthy....What other choice do I have? You got pics of your spray bomb effort? Suggestions for detailing the compartment without pulling that engine? Keep the hood down until further??
Let's hear it boy's!
Photo's are good too!
Edited by Spoiler II - 30-June-2014 at 3:03PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2014 at 3:22PM
not sure what you're wanting to do? do you just want a daily driver or show quality car? i personally like to paint all of the engine compartment the same color as the car, and the block too, it makes the shiny stuff pop! looks neater and cleaner IMO i also like to neaten things up under there too so it don't look cluttered, hide solenoids,wiring,  etc . behind panels, down low what ever to make it look clean and simple to show the engine, not all the rats nest of wires and hoses everywhere Cool
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spoiler II Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2014 at 4:28PM
nothing fancy..but clean is what I'm going for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spoiler II Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2014 at 4:30PM
Edited by Spoiler II - 30-June-2014 at 4:31PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spoiler II Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2014 at 4:32PM
kinda like that....
robot9000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robot9000 Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2014 at 4:38PM
There are no short cuts. I cannot see how to make the engine compartment look decent without pulling the engine and doing it right.  Too many nooks and crannies to touch up or polish.
2010 Mazda 6
2007 Jeep Wrangler
2011 Damon Daybreak 35BD
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2014 at 5:31PM
here's mine right after i put the engine back in, car's ALL apart now will be way more detailed when it's all back together all that wiring mess will be gone!!!
Edited by californiajohnny - 30-June-2014 at 5:32PM
mlachance112785 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlachance112785 Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2014 at 9:51PM
This is Semi-Gloss Black engine paint....
It's been almost 2 years since I did it. I still think it looks good.
77 Cougar XR7 460/C6
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2014 at 2:05AM
30 minute half-assed attempt right before I replaced the hoses, belts and drove it to the Moonshine festival. Quick and dirty, but still looks good. 250 in a '72 Torino wagon.
antlerfiend View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote antlerfiend Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2014 at 3:16AM
Does anyone have pics of Todd Whitelightnings engine? That is the way that I am gonna do mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2014 at 3:32AM
I have a picture of it. Will post it in a little while.
Are you asking about sprucing it up with everything in place or pulling the engine?
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2014 at 5:25AM
You can always start with hot water, a brush and some Simple Green. Scrub it down as much as you can then use a pressure washer to rinse (hot water unit will dissolve grease pretty quickly.
If you need to repaint, there's no shortcut, you got to pull that baby out and start sanding.
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2014 at 7:07AM
Here it is.
Edited by dave302 - 01-July-2014 at 7:08AM
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2014 at 8:17AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2014 at 8:18AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2014 at 8:19AM
Both of these are rustoleum 7777, satin black.  excellent match, pretty durable and touch ups blend well.
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2014 at 8:23AM
Here are pics of my '69 Cougar.  I taped off the fenders to spray bomb the engine compartment.  Pulled off the air cleaner and valve covers to clean, sand, and paint them.  Everything else was cleaned and painted just as it sat, without removing from the car, using lots of tape and patience.
Edited by n2fordwagons - 01-July-2014 at 8:28AM
Jeff
72 base Torino (modified)
72 Gran Torino Squire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spoiler II Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2014 at 11:48AM
That's what I'm thinking...with everything in place. It's a good running engine with only 88,000mi
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2014 at 2:30PM
Good way to see what you've got to work with. Just think before you spray with a pressure washer. It will force water into places you don't want. ESPECIALLY avoid the bulkhead connector and alternator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spoiler II Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2014 at 3:38PM
N2Ford...did you spray the block with a can?? or was it already done...
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 02-July-2014 at 12:35AM
Sprayed with a can.  The further you got down into the engine compartment, the less new paint was on the block.  From the bottom side, there was no new paint.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote antlerfiend Quote  Post ReplyReply Direct Link To This Post Posted: 02-July-2014 at 2:10AM
Thanks for posting the pic Dave. Todd hid most everything that he could. I plan on doing that to mine this winter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 02-July-2014 at 2:11AM
Yep. Allan made me a custom harness for the EFI setup going in Stripper and it is getting the full tuck as well.
429SPORT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 429SPORT Quote  Post ReplyReply Direct Link To This Post Posted: 02-July-2014 at 6:12AM
A LITTLE TRICK I HAVE USED WHEN DOING A "RATTLE-CAN RESTO" IN AN ENGINE COMPARTMENT WITHOUT REMOVING EVERYTHING. I'VE FOUND THAT TRYING TO TAPE AND MASK OFF SOME THINGS IS A BIT OF A CHORE AND VERY TIME CONSUMING. TAPE DOES NOT ALWAYS WANT TO STICK WHERE YOU NEED IT TO AND CAN BE AWKWARD TO CLEANLY APPLY. SOLUTION---TINFOILWink. IT BENDS AND CONFORMS VERY NICELY AND IS MUCH QUICKER THAN WRAPPING AND TAPING THINGS.
BEST WAY OF COURSE, IS TO REMOVE EVERYTHING. BUT IF YOU JUST WANT TO DO A QUICK CLEAN UP GIVE IT A TRY.
MIKE
1968 PONTIAC GRANDE PARISIENNE 427
1972 FORD GRAN TORINO SPORT 429
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 02-July-2014 at 6:41AM
That's a great idea!
This page was generated in 0.105 seconds.
