  New Posts New Posts RSS Feed - thermostat removal on 77 302 w/ac
Mark S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark S. Quote  Post ReplyReply Direct Link To This Post Topic: thermostat removal on 77 302 w/ac
    Posted: 16-May-2013 at 9:27AM
Hey guys:
Any trick to getting to the lower thermostat housing bolt on my 77 302 LTD II? It's behind the water pump with no room to swing a wrench. I've already pulled all the hoses and moved the distributor. Does the dizzy need to come out? Otherwise it looks like maybe the ac support bracket needs to come off, which means removing the fan and fan pulley. In which case, since the ac doesn't work, I might as well just ript all the ac stuff out. Or not. Any hot leads?
Mark
1977 Ltd II "Eltee"
1984 Mustang ragtop
2004 Grand Marquis Ultimate Edition
71 Torino GT 429CJ (sold too many years ago to count...)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark S. Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2013 at 2:18PM
For those who care (not many it seems) yes, the dizzy had to come out to get to the bottom thermostat bolt. But in the end, no big deal. Just a stupid design.
Mark
1977 Ltd II "Eltee"
1984 Mustang ragtop
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 28-May-2013 at 12:23AM
I did not want to be the one to tell him.If you do the front brakes you will find the hose so short the calp won't come off. books instructions state remove the brake line.To cheep to add a longer flex line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark S. Quote  Post ReplyReply Direct Link To This Post Posted: 28-May-2013 at 7:24AM
Ah yes, the thermostat. I called my buddy and he said he'd done a million of these; the dizzy didn't need to come out, I was looking at it wrong etc, etc. (He's a bona-fide expert on Lincoln LSC models with the 5.0 HO)
He came over, opened the hood, took one long look, sighed and said, "The dizzy has to come out."
End of story. LOL
Mark
1977 Ltd II "Eltee"
1984 Mustang ragtop
This page was generated in 0.151 seconds.
