Thinking about Edlebrock Top End Pkg, - Questions |
Post Reply
| Author | |
robot9000
Joined: 02-September-2011 Location: Michigan Status: Offline Points: 506 |
Quote Reply
Topic: Thinking about Edlebrock Top End Pkg, - QuestionsPosted: 28-December-2012 at 3:56AM |
Hi,
I have been looking at various options for an engine rebuild. Gonna pull the 351W and have it dipped and machined. They usually go .030 over, replace cam bearings, Magnaflux the block, crank and rods for cracks. The current low compression 2bbs runs fine, no smoke, so I don't expect anything unusual. I'm looking at various options and am leaning toward the Edelbrock top end kits for various reasons - good out of the box performance, all parts compatibility, no guess work for component compatibility, etc. I'm looking at kit 2092 - http://www.edelbrock.com/automotive_new/mc/power_package/tek_ford.shtml All I need except pistons and rings for the rebuild. Price is good for what you get. I have a couple questions tho... This comes with an Air Gap intake which is taller than stock or the performer. Has anyone used this and will it fit under the hood of a 73? Edelbrock makes it sound like its a lot taller than stock. so I don't want to go making holes in hoods, lol. The big question though is in looking at the HP and Torque spec's. While the numbers look good (400HP, 412 lbs torque) they all look pretty far up the RPM range for me. I'm looking for using this on the street, not the strip or a daily driver. It looks like you have to spend a lot of time north of 4K to make decent power. I know I can pick parts ala cart and probably get the power in the band I would prefer, but the All in One package is pretty tempting. |
Robbdtme
Joined: 06-June-2012 Location: Central WI Status: Offline Points: 765 |
Quote Reply
Posted: 28-December-2012 at 4:59AM |
Looks like some really good lower rpm torque which is more of your drivable power, I am thinking the high rpm rating before dropoff is because of the matched heads cam valve springs etc. giving you more rpm before valve float.
Edelbrock is usually pretty good if you call them and ask questions, They want you to be happy with your choice and what you want it to do. 2 things I would check on are I always thought air gap intakes were more for higher rpm ( But the torque specs on this package look good ), and second I would ask about stall rpm if you run a automatic, might need more stall than a stock torque convertor. While at it I would check on compression ratio higher is more power but at a point requires higher octane fuel as well. Sure this kit is setup for more than stock compression. Cheers! Friday is here!! Edited by Robbdtme - 28-December-2012 at 5:00AM |
Robbdtme
Quote Reply
Posted: 28-December-2012 at 5:04AM |
Oh for intake height the old setup has the egr plate which added a inch then a 3 inch aircleaner and about another 1 1/2 inch before hood so you have a few extra inches to play with then can gain some more if needed with a lower profile or say a 2 1/2 or 2 inch aircleaner so I would thing thing would fit but again a question to call the on.
I am assuming MI does not have emissions checks so the egr gets lost!! Edited by Robbdtme - 28-December-2012 at 5:05AM |
Quote Reply
Posted: 28-December-2012 at 7:45PM |
the summit listing for the cam shows 1500-6500 range, kinda wide, not sure i believe it?
a 224*/234* @.050" cam is barely in the stock converter range, but the 290*/300* figures put it solidly into stall converter territory
ok, did the math 71* overlap is too much for a street cam IMO. your comment about spending time upwards of 4K to make power is right with this cam, the 71* overlap will make it a dog at low rpm unless you have a decent converter & rear gear to get things crankin
what about emissions where you are?
Regul8r
Moderator Joined: 26-December-2007 Location: Sarasota FL Status: Offline Points: 6624 |
Quote Reply
Posted: 29-December-2012 at 7:58AM |
Thinking that is a set up for higher RPM POWER.
Will "WORK" for lower RPM but NOT optimally. peak power at 6k is at the top of the valve train capability too. You have to do alot of precision work to get the 351 running smoothe at that rpm. In our big cars I would be more inclined to pay attention to the torque/HP at lower RPM. Get one that runs decent at 1200-2500 and peaks at around 4000-4500 for the long shifts at the strip or from the light. You'll also keep the heat down in the tranny and keep solid power/not slipping driving around, by not having to run a high stall. |
robot9000
Quote Reply
Posted: 29-December-2012 at 1:39PM |
thanks for the feedback. The torque isnt bad in lower rpm, but with the max hp so high, i think I may look for a bit different cam profile. I think I might call Summit as suggested before I pull the trigger. car is in storage so no work until spring anyway.
For emissions, no tests here in Mi. And when we had testing, cars older than 10 years were exempt.
stanman
Joined: 23-March-2007 Location: Nova Scotia, Ca Status: Offline Points: 1434 |
Quote Reply
Posted: 29-December-2012 at 2:33PM |
Good plan. In my opinion, especially in a large heavy vehicle, torque is your friend. 400 HP isn't of much use on the street if it's at 6500 RPM's. High torque at low RPM's is the way to go.
Post Reply
| Tweet |
