TMeyer Track Boss Bypass Plate |
dan0R30 ![]() Senior Member ![]() ![]() Joined: 30-June-2020 Location: USA Status: Offline Points: 546 |
![]() ![]() ![]() ![]() ![]() Posted: 26-March-2023 at 3:33PM |
I bought a replacement bypass/restrictor plate for my 351C from TMeyer. My machinist didn't install it (they don't run the dyno with a thermostat), so I went to take a stab at it tonight. I am not able to get it to install flush like the OEM plate. Should it? Or is it ok if it sits a little above the lip?
The design is a little different between the two, so I got some measurements. The OEM measured 0.005" smaller in diameter and 0.055" thinner than the Track Boss. The Track Boss has the conical edge so it looks like it is meant to seal with enough pressed force. It definitely requires some leverage to get it back out, and its obvious the block is cutting into the edge when installed. I just thought I'd see if anyone has installed these before. I also bought a TMeyer thermostat so I figured these were designed to go together. But from what I gather I should be able to throw my OEM back in if this is an issue. ![]() |
Dan
1970 Ford Torino hardtop - 351C 4V - FMX - 9" 3.00 |
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5442 |
I am not sure on that one Dan. Maybe Rock will know. Or reach out to Tim. He's usually pretty good at getting back to people if they are customers. If you contact him, just tell him you are a customer in your message, as I know he gets tons of calls for free advice.
That's a good idea, I will try to reach out to Tim (with my order number just in case). Thank you.
Dan
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 5846 |
comments i've seen, yes Tim's restrictor sits higher in the block than the original. if i understood one customer's comment he suggested that the TrackBoss restrictor is so thick that it prevents some / if not all T-stats from opening completely. IDK? IMO there's nothing like the real thing, Baby FlowKooler is marketing a 351C T-stat restrictor that has a smaller diameter orifice to be used with the incorrect generic Windsor and chevy style 'Robertshaw 330 series' T-stat. the correct T-stat for a 351C engine is the Robertshaw 333 series which has the special hat / sleeve on the underside to effect the shut-off of coolant flow through the restrictor orifice. the FlowKooler's smaller diameter orifice doesn't need the hat / sleeve and shuts the bypass with just the sensor bulb of the T-stat. ![]() to further complicate matters there's this air bleed hole plate that's advertised as allowing the removal of the T-stat ![]() and i remember a guy that posted to the Pantera International page that made and sold his own plates on ebay, neonfiddler IIRC ![]() https://www.ebay.com/itm/185424040123?hash=item2b2c2250bb:g:hNAAAOSwjaldNgeQ
Edited by Rockatansky - 27-March-2023 at 12:04PM |
Thanks for sharing those Rock, it's good to have options. My biggest worry is that it would restrict flow to the radiator by not opening completely, like you mentioned. His design is to make sure the bottom is completely flush so that it doesn't recirculate in the block, but maybe that difference is negligible.
Tim got back to me pretty quickly last night and again this morning. To paraphrase his responses: I didn't think it was bottoming out based on my initial depth measurements of the plate seat, and so I re-measured it to be sure. While the depth is not flat throughout, the lowest spot I could measure was 0.174" closer to the middle (average was 0.2"). However that low spot should still give 20 thou of clearance if the plate were completely seated. It's possible there are two areas that are bottoming out where my gauge can't measure. (Yes I know it's ugly, I let the block sit too long after the dyno). I'll clean it up a bit as he recommended and go from there. ![]() |
Dan
Glad Tim was able to help you out. Keep us posted.
72 RS 351 ![]() Senior Member ![]() ![]() Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 2444 |
Yes, thanks for the discussion and the options for it. I would tend to want the altered bypass plate along with the Robertshaw model 330 that it's made for. I prefer a 180* most of the time, and the model 333 may be harder to get at some times, in the rating you want.
Inkara1 ![]() Member ![]() ![]() Joined: 17-November-2021 Location: Ridgecrest, CA Status: Offline Points: 127 |
When I changed the thermostat as preventative maintenance on my 351C with unknown history, I bought two 180-degree thermostats and a bypass plate. The second thermostat is in case TMeyer isn't still in business next time I need a thermostat, and the bypass plate was in case the original one was gone. The original one was still there, so I just left it. I can say the TMeyer thermostat works great with the original plate. No overheating issues with the Champion radiator so far now that I got the distributor timing under control.
Thanks for sharing, another good data point. And good call on keeping extra stock around!
Well I was able to clean up the seat a bit and finally get the plate in albeit with more force than I wanted. Used a big socket and you can tell. But it's in there and it's not coming out. Sits just below the threshold too. ![]() ![]() |
Dan
