  New Posts New Posts RSS Feed - Sports Gauge Faceplate in woodgrain?
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Topic: Sports Gauge Faceplate in woodgrain?
    Posted: 05-November-2014 at 7:02AM
Here's how my cluster looks now.  Notice the woodgrain.
Eventually, I'd like to install a full set of newer gauges in my Montego wagon, using a Sports Gauge faceplate.  Is there a sports gauge face plate out there that will match my woodgrain?  Or, am I limited to black and the funky holographic pattern pictured below.
Jeff
71 Torino Brougham
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 05-November-2014 at 7:31AM
Elites had the sport cluster with wood grain. What you have pictured above is from a Sport. My 75 Sport has that exact same "early graphite" design.
Webmaster
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 05-November-2014 at 8:16AM
Awesome.  That's what I need to know.  Now, to find me an Elite cluster faceplate.
Jeff
71 Torino Brougham
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 05-November-2014 at 8:28AM
Jeff, my old wood grain dash cluster in my wagon actually was a metal piece that could be removed from the plastic housing via small tabs on the back. If you are a DIY'r maybe some of the vinyl wraps below could spruce up the new one.
http://www.topvinylfilms.com/wood-grain-wrap-vinyl/
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 05-November-2014 at 8:32AM
Thanks for the link Carlos.  I did think of that, but not sure how well it might match the rest of my woodgrain.
I found a completed ebay auction.  Supposedly this came out of a '75 Cougar XR7.
Edited by n2fordwagons - 05-November-2014 at 8:33AM
Jeff
71 Torino Brougham
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 05-November-2014 at 8:41AM
I know that at least some Cougars had the padded bezel.
Retired 60s NHRA Anglia
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 05-November-2014 at 9:11AM
Jeff, all Sport clusters built after 1974 had the "Unleaded Fuel Only" designation. That looks like the set of gauges I have from my '75 XR7. It had the padded cluster coverplate, though. I think all '74 and '75 XR7's had that padded setup. However, they all (from 1972 - 1976, maybe even 1977 to 1979) had the same spacing between gauges and used the same basic housing, so any year cover will work. The most important part is getting the right cluster year as your car for wiring purposes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 05-November-2014 at 10:42AM
Joe, I was thinking of getting a set of aftermarket gauges, and somehow installing them behind a sport gauge faceplate.  I have no idea how or if it will work.  Or, if the aftermarket gauges would be the correct diameter.  You were looking at some gauges while we were at Louisville.  Is that what you were thinking of doing?
Jeff
71 Torino Brougham
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2014 at 1:49AM
Yep. If you'd like, I can write up a detailed explanation of what we talked about last night - in case other members are interested in doing the same thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2014 at 2:29AM
That would be awesome!!  Smile
Jeff
71 Torino Brougham
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2014 at 5:18AM
Yes, all 74-76 XR7's had the padded trim.  As mentioned, the woodgrain was Elite.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2014 at 11:59AM
YES PLEASE!!!
I want to put aftermarket in the Rally car!
Maybe just doing it as a custom cut face plate without using the actual face plate.
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2014 at 11:35PM
Not to be a spoil sport, but the wood grain pattern on the ltd2 is different than the caugar and tbird.At least on the ones I have seen.The merc has a more pronounced pattern.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 07-November-2014 at 1:00AM
There are at least 4 different types/species of wood grain used in mid-late 70's intermediates. I have a small collection of GT gauge surrounds as well as the trim pieces that house the A/C vents that mounts above the glove box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 07-November-2014 at 1:31AM
Are any for sale?  Any chance you can provide side-by-side comparison pics of what you've got?
Jeff
71 Torino Brougham
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 07-November-2014 at 4:51AM
  I will try to post pics of the surrounds that I have and a description of their respected condition. Everything I have is for sale...for the right $. Wink  Todd
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 07-November-2014 at 8:15AM
OK, I found my surrounds but they are all either padded or GT, I cannot find the wood grain ones other than the one I am currently using. I do have pics of the different "woods" used:
The surrounds I did find.
This shows different part numbers and possible color designations, BB, CB and BA.
This one would be my favorite color, can't find the matching gauge surround, A/C vent trim and/or A/C control panel trim. Notice the last digit is "C"
This is the panel I am using in my Ranchero now.
Just as a "BTW", if you need to touch-up the silver around your gauge cluster or any part of the dash, this works excellent. It is a Silver leafing pen made by Krylon and can be found at most craft/hobby stores.
Sorry not to be of any more help, hopefully the other surrounds will turn up. Todd
Edited by aquartlow - 07-November-2014 at 8:15AM
