torque converter help fmx |
Post Reply
| Author | |
slow72
Joined: 12-December-2014 Location: Rochester ny Status: Offline Points: 1 |
Quote Reply
Topic: torque converter help fmxPosted: 14-December-2014 at 11:02PM |
Im running a decent 351w in my 72 with stock hears and an fmx trans. The car will do great rolling burnouts but leaves the line like a pig. It seems like there aren't very many options for torque converters out there for that fmx. Has anyone had any luck?
Josh Mcclean
*72 formal roof torino *73 ranchero 500 *55 Studebaker Chanpion *70 Maverick 6cly *88 F250 hd |
Joined: 30-July-2010 Location: On The Road Status: Offline Points: 6398 |
Quote Reply
Posted: 15-December-2014 at 2:40PM |
you won't find much / if anything at all listed in sale ads but a decent converter can be built by just about any outfit that isn't stuck in an assembly line mentality
could be your rear gear too, any idea what it is? a 2.5 or 2.75 rear isn't gonna impress off the line |
Joined: 25-August-2013 Location: New York Status: Offline Points: 4195 |
Quote Reply
Posted: 16-December-2014 at 11:07AM |
3.25 or 3.50 will put a smile on your face.
![]() You can get FMX convertors, but shift kits, etc., not so much. FMX is kinda the unloved ford transmission.
Quote Reply
Posted: 16-December-2014 at 12:29PM |
still basic principals apply. remove the 'puck' from the VB, source good frictions & steels from the AOD section, cut a new snap-ring groove to add a clutch if there's room or the AOD clutches may be thinner so they'll fit more w/o moving the snap-ring. lighten or remove the accumulator springs, lighten or spring the governor, enlarge / chamfer exhaust ports, drill drums, widest possible band, shim the pump regulator spring... and it goes on you can build a snotlocker FMX
ramair351
Joined: 08-May-2006 Location: west michigan Status: Offline Points: 1561 |
Quote Reply
Posted: 28-December-2014 at 12:13PM |
TCI makes a decent convertor, and you can get a nice shift kit too by transgo
http://www.drakeautomotivegroup.com/Store/Product/C9ZZ-7A100-SK.aspx?wid=141 i had a fmx built up for my 73, it was tough, and shifted nice
-Pete
1972 montego GT 1970 Torino cobra SCJ 1970 mustang mach 1 1965 Falcon futura |
kychevyguy
Joined: 16-December-2013 Location: Lexington KY Status: Offline Points: 1996 |
Quote Reply
Posted: 01-November-2015 at 3:10PM |
all good info to know
JT, USAF Ret./Architect
1971 Ford F100 "Lizzy" 1971 Cougar XR7 "Kitty" 1984 Chevy Silverado "Sylvia" 2009 Smart Fortwo Cabrio "Lil Dude" 2015 Volvo XC60 R-Design "Sven" |
ilyes
Joined: 09-January-2010 Location: Philadelphia PA Status: Offline Points: 3782 |
Quote Reply
Posted: 01-November-2015 at 11:05PM |
I got a Boss Hog converter in my FMX, night and day difference at the light. I couldn't idle the engine with the old one, now I'm fighting for traction.
antlerfiend
Joined: 14-June-2010 Location: Louisville,KY Status: Offline Points: 3023 |
Quote Reply
Posted: 02-November-2015 at 2:05AM |
I have two FMX trannys that shifted awesome stock. I switched to a C4 because of cheaper parts and lighter weight. Monster transmissions has a stall converter for FMX trannys. Put a stall in it and you will absolutely love it.
72 GTS (Morgan's Baby) 68 CJ Drag Car Clone 65 Mustang (first car) 77 LTD II (Drag Car) 78 Mustang II V6 4 speed |
Post Reply
| Tweet |
