  New Posts New Posts RSS Feed - 72 passenger door lock?
russosborne View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Topic: 72 passenger door lock?
    Posted: 06-May-2015 at 9:43AM
On mine I cannot lock the passenger door with the key,it only works to unlock.  Is this normal or do I have a lock issue?
Thanks,
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 06-May-2015 at 9:54AM
spray some lube in to the lock and work it.
Might have to take the door panel off and check the linkage or spray it all as well.
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2015 at 6:23AM
DONT USE SPRAY LUBE.  USE POWDERED GRAPHITE LUBRICANT.  COMES IN A SMALL TUBE.  SPRAY LUBE WILL EVENTUALLY COLLECT MORE DUST/DIRT AND YOU'LL HAVE THE SAME PROBLEM AGAIN.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2015 at 10:34AM
DO NOT use WD-40. As the locks wear, the anodizing on the aluminum wears away, and WD-40 will eat into the metal of the lock.
This page was generated in 0.106 seconds.
